Will these BBS wheels fit my 930 turbo?
So interesting discovery - no spacer behind the rear wheels. The front has a spacer and seems to be proper fit...the rear as I mentioned is about 2 inches inside wheel well. Wonder if shop that did rear rotors forgot to put the spacers on. Of ourselves they don't remember ....
The rear spacers may have been removed to fit larger/non-factory offset wheels. Factory 930 Turbo flares (3 and 3.3 liter) will easily accomodate 9 inch Fuchs (w/ factory offset) with the spacers installed but if you go to a larger than 9 inch wheel (or non-factory offset), the spacers have to be removed.
Factory spacer on the rear should be 28mm.
