Best Material Used for Headers
I'm looking into getting a set of new headers or even getting some custom fabbed, i noticed some manufacturers uses ss304 and some uses ss321; can anyone enlighten us as to which material is BEST regardless of cost? I know for exhausts Titanium is the no comprimised material of choice but how about for headers??? Any discussion would be appreciated.
thx, that burnsstainless site was great. Anyone have an idea how much more is Inconel vs. say ss 304 for reference? Also are they any companies out there that makes Inconel systems for Porsches??
Titanium gets brittle and cracks, and typically isn't recommended for a long term option. But if you want to through a ton of money at it go with Ti and build a spare set when the first cracks.. Money no object. 321 is a good alloy because it does have Ti in it.. Inconel is very good for high heat. If one needed a practical system build it using 321 and bump up the wall thickness.
Originally Posted by 38D
Inconel is the best material for headers, period. But a custom set will run over $6k.
The advantage of Inconel is for sure the ability to widestand higher temps then
stainless steel.
From that, the wallsize can be lower then stainless steel.
The material weight is slightly higher then stainless steel.
On proffessional race cars, every small weight is important.
With inconel headers you can save few gramms.
That why inconel is used.
But how that big price difference for a 930 Inconel header
will pay out?
I mean, for sure its fancy to say:
"Inconel headers" :-)
Falk
Holcombe headers run in the $4k range. One of the issues with headers cracking is that there are no slip joints to allow expansion of the engine case so the headers get stressed. I'll look for a picture of mine.
Originally Posted by Falk930
On my opinion Inconel is not the material for "standard" or basic track cars.
