*The official WUR thread*
Former Vendor
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
So many questions about WURs.....probably the most important component of most of the cars we own.
So, let's start a 'sub-forum' on WURs in general!
I'll start. Is it safe to say that the idle mixture only has an effect on fuel mixture *until* the WUR kicks in and delivers full boost full enrichment?
Can't answer that, but what happened to Brent 930's RPM activated WUR? He used an MSD rev controller to adjust it (along with some internal mods maybe)? Seemed like a good and cheap way to go.
https://rennlist.com/forums/showthre...&highlight=wur
Originally Posted by 38D
I think that is correct. After the engine is warm, it is all about the hex head adjuster on the fuel dist.
Originally Posted by DeWolf
I would take it that turning the adjuster clockwise would lean it and anti-clockwise to richen?
CW=RICH
CCW=LEAN
https://rennlist.com/forums/911-turbo-930-forum/297546-a-crazy-little-thing-called-a-wur-warm-up-regulator.html
By doing the basic WUR mod and INCREASING my cold fuel pressures (I was originally too rich), everything changed for me. At start up and at WOT. My AFRs are stabalized acrross the RPM range. Don't forget I also have the Imgine Auto fuel head. Obviously there is room for improvement, but the car has been transformed...for now!
The Brent 930/Brian Leask RPM Switch/Solenoid solution consists mainly of the Solenoid: OEM-91161812300 called Change Over Valve and the MSD RPM Activated Switch, I believe it's part number 8950 and there's an RPM Module to go with it to. I believe you'd need to choose the RPM module that you need, probably the 4000RPM one, or the more expensive adjustable one where you can adjust the RPMs based on the needs. I think Brian is working on a kit that will be easy to install as you need wiring and brackets to go with these parts. Brian, please correct me if I am mis-stating something here.
Pelikan is out of stock with these Change Over Valves so if you need this mod quick and can get one off your car (I guess belonging A/C system), that's the way to go.
I think the above RPM switch/Solenoid solution combined with the adjustable WUR is as good as we can have it with CIS.
Originally Posted by WERK-I
L-L....R-R
turn Left to "Lean", Right to "Richen".
Now, back to our regularly scheduled programming........WUR
BTW. what I am writing about the RPM switch here is something I have just very recently learnt from Brian Leask. So, I admit that I lack any solid experience that goes with these couple of comments I posted.
Hello,
I have a 84 Euro fuel system. The car runs really rich at all times. At WOT I noticed it feels rough. After 20 minutes of idleing its soo rich I can't barley stand close to it without having my eyes burned off. I decided to connect a CIS tester and run a couple of tests to see what the WUR was doing. Ran the fuel pumps while the WUR power is disconnected and the CIS tester tapped in between the Fuel Head and WUR, and this the reading I got 19-20 psi. I then connected the power back on and started the car Cold and this the reading I got, 59psi. The gauge did not fall below 59 psi, even when the car was warmed up. From what I've read, the operiatning fuel pressure should be at 20 psi. Does these readings indicate the the WUR is not working correctley? Any ideas to what might be happening here?
Daniel
Daniel
i didn't know Brian was following up on Brett's idea (or their idea). I had seen a picture of Brents at one time, but couldn't find it last night.
Originally Posted by Olli
I think Brian Leask is sort of continuing on Brent 930's path and to my knowledge is the only one doing it today to help others.
Former Vendor
I have the Brian Leask RPM switch setup here, ready to install. Incredibly complete, prewired, ready to install, absolutely awesome directions. Could not be better in any way
With no garage at home I have to wait for the rain to stop in order to install it ;-)
Already installed the Leask WUR - already a significant difference from stock.
IMO, the Leask setup IS A MUST FOR OUR 930s!
Trust me guys, the Leask setup is THE setup for the 930s. Just look at my dyno and check out that before(blue) and after(red) torque and AFR...
http://northeasttarrantderm.com/davi...ynoResults.jpg
