What is green wire on side of distributor?
03-10-2006, 10:52 AM
What is the green wire for that plugs into the side of the distributor?
03-10-2006, 10:55 AM
Can't remember if it's to the coil or CDI Box? Or neither for that matter...I'm just thinking out loud, here...
03-10-2006, 11:05 AM
It's got to be the CDI Box. I don't remember a connection to the coil involving that green wire.
03-10-2006, 11:06 AM
I believe that's the distributor pulse signal to the CDI. The green wire should be available by itself.
03-10-2006, 11:07 AM
Its the trigger wire from the magnetic pick up in the distributor. It goes to the CDI.
03-10-2006, 11:53 AM
thx. ...i have MDS ignition so it must somehow be going to that.
03-10-2006, 12:43 PM
03-10-2006, 01:30 PM
Remember that it's not really a wire but a cable with two cores.
03-10-2006, 06:04 PM
yea, found the coax part out the hard way! it's pain to get at the plug and remove with everything intact so i figued while i did rebuild i'd just split wire and put connector in. ...now it has two connectors each end.
