911 Turbo (930) Forum 1975-1989
Rings in backwards
Old 02-12-2006 | 07:26 PM
JBrown's Avatar
JBrown
Default Rings in backwards
My engine is apart getting new rings, too much boost cracked rings in two cylinders. Anyway my mechanic told me that in one cylinder the rings were in backwards. can that be? Motor seemed to run fine before two much boost. Engine had only 5000 miles on it. Thanks
Old 02-12-2006 | 08:22 PM
sand_man's Avatar
sand_man
I think there is a "top" and "bottom" to piston rings.
Old 02-12-2006 | 08:37 PM
mark944turbo's Avatar
mark944turbo
I think somebody did this once in the 944 turbo forum, it screwed up his cylinders pretty good. There are definately top and bottom rings, but I think it is more likely that he meant they were in the right place but installed upside down.
Old 02-12-2006 | 08:43 PM
Kevin's Avatar
Kevin
Yes, there are top and bottoms for the 1st and 2nd ring.. Rings crack due to detonation.. Not enough fuel for the boost that you were running.. I would definately inspect and measure your ring lands, and have the two pistons zy-glowed (checked for cracks)..
Old 02-13-2006 | 09:03 AM
JBrown's Avatar
JBrown
Had cylinder cked and i am sorry i ment upsidedown.
Old 02-13-2006 | 09:05 AM
JBrown's Avatar
JBrown
had pistons checked
Old 02-13-2006 | 09:32 AM
Geoffrey's Avatar
Geoffrey
The rings also have a top and bottom, so not only is it possible to swap the two compression rings, but they can also be installed upsidedown
Quick Reply: Rings in backwards
