Can't Remove Cyl #1 Sparkplug 87 Carrera
4th Gear
I am replacing the plugs, wires, cap and rotor on my 3.2L 87 Carrera. R&R'd all plugs but #1, which I thought would be the easiest. (closest to distro, easiest to access), but...
I cannot get a purchase on the plug hex. The spark plug socket doesn't seem to go all the way down as it did on the other 5 plugs.
I looked with flashlight and mirror and cannot see anything obstructing. Quite frustrating!!
Never had this issue before, (changed plugs in 911E, SC, 912E, 356, 914) . This is my first go on my 3.2 Carrera. Is there something different about #1? A special trick? I tried different angles, jiggle on and other "Gi'me a break!" actions, but nada!
Any thoughts would be greatly appreciated. Big drive next week, plus a smog check prior...so why is this plug stumping me?
Cheers,
Geary
Cheers,
Geary
The factory spark plug tool would be the best to use in that case ... is the rubber insert displaced in your socket ?
Try using a regular socket without the rubber insert,you might get a better fit !
Cheers
Phil
Cheers
Phil
You might think this tongue-in-cheek, but it's not.
Have you looked into the plug well with a mirror or anything? I was helping a friend of mine pull maintenance on his 3.2 once and we had the same problem. Looking into the hole at the plug we found the area around the plug filled up with nuts (I don't remember the variety)! It seems little critters just love hiding things in areas like that.
We rigged a small nozzle on the end of a vacuum cleaner hose to suck them out of there and the problem was solved. Some we had to break up with a screwdriver to promote that. But in his case it wasn't just one plug well, but several.
Anyway, worth a look if you haven't already (and an amusing story to boot.).
Team Owner
first thing i thought was rubber left on from previous socket. if that is the last one po did he may not have noticed. i like both suggestions above.
4th Gear
Solved!
Success! Dug out my tool kit and used the spark plug tool. The plug was bit stiff to remove, (torque required versus the other 5 plugs). New Magnecore wires, cap and rotor, cat back in...bring on the smog test!!
Thanks to all who responded!
Cheers,
Geary
Cheers,
Geary
4th Gear
Crap!
Saturday morning....drove like crazy, nice hot temp, cat cooking....Smog test measurements all super!
Notice the F'in FAIL? Tech looks under the RR wheel well and sees the charcoal canister, reaches up a tugs the large hose, hits the small hose and it breaks off.... FAIL!!!!
Mad dash to Parts Heaven in s#!tty traffic, they were kind enough to wait for me until 35 minutes after closing. $24 new hoses. Installed today, back to SMOG tomorrow!!!
Cheers,
Geary
Cheers,
Geary
