911 Forum 1964-1989
Targa Seal install
Old Apr 15, 2012 | 03:53 PM
theiceman's Avatar
theiceman
Team Owner
Interesting story. Wonder if I will have to cut mine down. Even if I do no big deal. It's the rear I need anyway.
Old Apr 15, 2012 | 05:16 PM
SARGEPUG's Avatar
SARGEPUG
Originally Posted by HarryD
Read this: http://forums.pelicanparts.com/porsc...-solution.html
Ignore Dan at your own risk.
Nice post, but this thread also only refers to 86-89 and Pelican warns about those 3.2 years as an issue. I am starting to think that the 86-89 Targa Top is different than 84-85 and that is the issue. I also did research on Pelican's site and see that many Targa Top components are up to 85' specifically, which further reinforces my toughts. I think I will do a front seal dry run (not glued) and see how the top fits on it. Glad to know that the Roll bar seal is a non issue.
My dilema is that I brought both seals out to the vacation home awaiting my install and by the time I return, I might be outside the return time frame.
Old Apr 15, 2012 | 05:18 PM
SARGEPUG's Avatar
SARGEPUG
Originally Posted by Ed Hughes
I believe that to be erroneous information. I had the problem on my '84. To my knowledge, they are all the same seals. Some of the hardware changed over the years, but the windshield frame, and the tops are the same. Once again, call Dan @ Cars Inc-he will give you all you want to know on Targa tops.
Ed,
Did you have an 84' top? Was it refurbised or from 86-89? As I posted above, Im beginning to think 84-85 tops are different.
Old Apr 15, 2012 | 07:26 PM
theiceman's Avatar
theiceman
Team Owner
and i think the 78 tops are even different again .. my seals get here Thursday and i am picking them up on the way to hershey .. if Dan is there I iwll have him hava a look at them ..
Old Apr 15, 2012 | 08:15 PM
HarryD's Avatar
HarryD
Iceman:
E-mail Dan and find out if he will be there. He has been helping me with various Targa issues for years and has very very happy to communicate.
Old Apr 15, 2012 | 09:21 PM
theiceman's Avatar
theiceman
Team Owner
No need to harry I am going regardless and will have my seals. He was there last year
Old Apr 16, 2012 | 12:32 AM
Ed Hughes's Avatar
Ed Hughes
Originally Posted by SARGEPUG
Ed,
Original '84. As mentioned the new seals sold these days are the 964 variant.
Old Apr 16, 2012 | 07:21 PM
SARGEPUG's Avatar
SARGEPUG
Dam glad I started this post!
I received my RMA number for the windshield seal and ordering from Dan's tonight. Thanks for all the great info!
Old Apr 22, 2012 | 04:58 PM
theiceman's Avatar
theiceman
Team Owner
okay i got all my seals ... two top seals look pretty solid and back one is perfect. I am going to assume the front is a 964 seal as others have noticed as it seems beefy but i havent drilled down yet as i am working on the rear one.. Just in time as the old one came out in three pieces in about 30 seconds .. tthe channel is full of old glue and years of filth .. any recommendations for removing the old gue ? I know varsol will do it but was looking for something a little less harsh.
Any suggestions ?
Old Apr 23, 2012 | 01:19 AM
User 4221's Avatar
User 4221
I typically use a good citrus cleaner on this type of work. It degreases and softens up the glue.
Old Apr 23, 2012 | 08:27 AM
SARGEPUG's Avatar
SARGEPUG
I received my front seal from Dan and returning the Pelican one today. I am naturally keeping the Targa bar seal from Pelican. I'll post when I install.
Old Apr 23, 2012 | 09:06 AM
theiceman's Avatar
theiceman
Team Owner
i will try the citrus cleaner and see where we get .. may be a bit of a tricky job as some of the glue is rock hard and you have to work with the roof out so could be a bit messy.
Old Apr 26, 2012 | 02:28 PM
luc bernier's Avatar
luc bernier
Cruisin'
any pics on how to replace these seals ?
Old Apr 26, 2012 | 10:02 PM
theiceman's Avatar
theiceman
Team Owner
pull out glue in for the rear
for the front take the metal strips out of the header along the top pretty simple really
Old May 10, 2012 | 01:26 PM
SARGEPUG's Avatar
SARGEPUG
I'll be tackling the install at the end of the month. Won't be at Vacation home till then. Any you tube vids showing the procedure?
