Restoration...which engine to get...why ('78 911SC)?
So I'm restoring a '78 SC Targa and I'm thinking instead of trying to get the current engine running/sorted out (car has been sitting for 3 years and the engine looks beat up) that I'd consider purchasing a running engine. I'd like to hear your opinions on which engine to get and why (3.0, 3.2, etc).
I'd love to have a high performance engine but I don't think I want to spend that much (not unless it's really cheap), so as long as I can bolt it on and go the better. I'm also not looking to break the bank either so is up to $3000 a realistic price for a used running engine?
I'm not opposed to getting the same type of engine that's in there now but if I can get something better that's reasonably priced I may as well go that route.
Thanks for the help/advice
I haddah Google dat
The later SC engines had higher compression and lambda feedback control. I would consider updating the hardware such as studs, rod bolts, etc, and bumping the compression and cams.
I wouldn't expect to find a good running engine for $3000. Don't buy anything from Motormeister. Do you know your engine doesn't run with some fresh gas, fresh oil, new spark plugs, new distributor rotor and cap?
Brett
Brett
+1 for not getting a new engine.
Post some pics of the current one, how beat up is it?
It may be cheaper/smarter to get the current engine rebuilt if it even needs that.
What problems does the current engine have, does it turn over, does it run at all, do you have spark, do you have gas getting to it. How is the compression. I would not jump straight in to getting a new engine until I knew what was wrong with the current one.
Regards
Dave
Regards
Dave
@Jay
What makes a motor euro spec? I know they had more hp but how. I have a 78SC, what would i have to change to make it euro spec, that bump in power would be quite nice.
PS-what is up with all of the @'s these days? It would suffice to address: Jay. This isn't twitter. Sorry, but this new era doesn't make sense in many ways, especially when ADDING a keystoke. I'm used to the shortcuts; u, ur, OMG, etc, but the @ is plain silly.
Thanks for the responses guys. I'll snap a video in a couple of days as the car is at another house. I'm not sure what is wrong with it to tell you the truth. I can see it wet from underneath, so I can assume there's a leak of some sort. I haven't tried to start it as I'm not sure if everything is connected or there (the prior owner was working on it and never finished). I need to check the gas tank as something is leaking in that area (suspecting it's old gas as it has the smell of old gas).
I read a little on Motormeister so yes I'm staying away from them. I saw a motor on ebay from a Porsche shop/dismantler in CA a couple of weeks ago and it was around $3k so I was going on that for pricing.
Without having a lift, is there a way to drop the motor safely?
I wouldn't just start it without going through the basics. I would check plugs, change oil, fresh gas and clean up everything before I even dreamed of starting it.
That engine defiantly needs some work. Price wise that more depends on if it starts or not.
+1 on doing every thing before starting it. Just based on exterior rust that oil filter and fuel filter have to go. I would get a new distributor cap and rotor as well. As for getting a new engine that comes down to a few things.
-How much work do you want to do
-How much work do you want to pay to have done
-Do you just want to drive the car or do you want a project.
If you want a project and want to do a good deal of work, I say keep the engine. Drop it out, break it down and clean it up. Personally I love doing my own work I find it very rewarding and I come to be far more attached to the cars. You will learn a great deal along the way as well. Some of the work you will find you simply cant do, like say powder coating the fan. You will need quite a few parts if you want the engine looking like new. The price may in the end be about the same, I say fix the current engine, if that is the original engine for the car all the more reason to.
As for dropping the engine, yes it can be done with out a lift. I have never done it but i know many who have. you will need at least a jack and some jack stands.
Yes, you can. You'll need a floorjack, and preferably an ATV jack. Some jackstands capable of about 26" of lift, and a couple of smaller jackstands. It's pretty well documented-look at Wayne Dempsey's 101 projects book.
Just work safely and go slow.
