911 Forum 1964-1989
Window Outer Seal Length
Old Apr 8, 2009 | 12:36 PM
salukijac's Avatar
salukijac
Default Window Outer Seal Length
Does your outer window seal (squeegee) run the entire length of the window or is there about an inch gap? Mine has some play close to an inch so you can slide it back and forth.
I washed the car yesterday and this morning when I rolled down the window, it was still wet.
During the last visit to the mechanic they had to replace the window regulator and they said the window support bar was rusting.
Does this seal keep the water from entering the door? Should it run the entire length of the window? I was thinking about ordering new ones but not if there going to be the same length.
Old Apr 8, 2009 | 02:40 PM
theiceman's Avatar
theiceman
Team Owner
mine did shrink over time and my replacenment ones covered the whole window. I found them really easy to replace having a targa too . Not sure how dificult it is in the coupe as I don't have the whole window surround.
Old Apr 8, 2009 | 03:17 PM
GothingNC's Avatar
GothingNC
Thanks Iceman for adding another project to my "list"
John
Old Apr 8, 2009 | 03:31 PM
salukijac's Avatar
salukijac
Here are a couple of pics of what mine look like. I'm surprised that they would shrink that much.
Old Apr 8, 2009 | 04:15 PM
rusnak's Avatar
rusnak
I haddah Google dat
I heard the same thing about shrinkage, not that I would know anything about that...ahem.
Old Apr 8, 2009 | 05:17 PM
theiceman's Avatar
theiceman
Team Owner
was your car in the pool ?
Yep John you will have to spend all of about $6.00 per side on this one , and about 4 minutes for us Targa guys.
Old Apr 8, 2009 | 05:25 PM
theiceman's Avatar
theiceman
Team Owner
oops , that was a bit bigger than I expected. now I know why porno stars don't like hi def. You see every blemish ...
Old Apr 8, 2009 | 06:03 PM
salukijac's Avatar
salukijac
Thanks theiceman,
Amazing, isn't it? And that's on a car that spends most of its time garaged...either that or the seals come in different lengths and I have the wrong one. On to pelican to order replacements.
Old Apr 8, 2009 | 08:18 PM
theiceman's Avatar
theiceman
Team Owner
Actually they do shrink , not many of our cars have he correct length anymore cause people don't hink of replacing them . When I walk around Hershey they are ALL shrunk ..
Old Apr 8, 2009 | 11:21 PM
84_Carrera's Avatar
84_Carrera
Legacy Flounder
I just ordered up all new seals for my '84 Cab while doing the soft top replacement this month. I should have them Friday if I can get the Fedex driver to leave them...
Old Apr 8, 2009 | 11:42 PM
theiceman's Avatar
theiceman
Team Owner
You just better hop it's Not Doug Heffernan delivering them ..
If you guys are off Good Friday down there looks like you will have a long weekend to get some work done...
Old Apr 10, 2009 | 08:31 AM
GothingNC's Avatar
GothingNC
Iceman,
Just checked the seals out on my Targa and they are in almost new condition
PO had them replaced along with the door seals.
I also discovered that the door-stay reinforcement kit is already installed,
John
Old Apr 10, 2009 | 09:30 AM
theiceman's Avatar
theiceman
Team Owner
wow great news .. I had to put on the door stay enforcement kit last year as my door was torn when i got it. I got to it just in time. That is one project i would recomend for absolutely everyone with cars of our generation. MAkes you wonder about the seals for the window , easy to do yet so many need doing
Old Apr 10, 2009 | 01:43 PM
GothingNC's Avatar
GothingNC
Next seal that might need to be replaced is the rear Targa Window.
It is not leaking but is getting hard in spots.
Jihn
Old Apr 10, 2009 | 03:53 PM
theiceman's Avatar
theiceman
Team Owner
that's the spensive one no ?
