Do you ever blow fuses?
I thought it was fairly common to blow heating system fuses on these cars? After all, if you look at how some of the motors are built, you can see how easily they wear out and would short out any fuse after awhile. I wouldn't worry about it unless you continue to blow the same fuses over and over again. You might have to start testing the motors in question in that case...
