Quick valve adjust question
After adjusting my valves and closing her back up I have noisy exhaust valve in the right bank so today I'm opening her up again to check that side once more.
I used the backside method to determine if any valves needed adjusting and if they did I used the direct method to adjust them, then verifying with the backside method.
My question is: exactly how much out do they have to be before they generate some noise? It seems as though using the backside verify method I should be within .0005 of the specified .004.
Also a bonus question, if I only jack up the right side and remove the bottom valve cover how much oil will spill? Just wondering if I should completely drain the crankcase again or if I can get away with it without a drain?
Thanks! I did find my just barely loose valve today. Hopefully I can get this right on the third try :-)
And I finally managed to break my tranny drain plug free with an improvised 17mm hex socket (chopped the end of the allen wrench off and stuck it in a 17mm socket) and big breaker bar so I'm just about done with the 60k service after only three weeks lol.
Team Owner
Team Owner
I was fortunate that my adjust was very good. i found it really helpfull to tuck the guage under the rocker on the valve side and sort of rotate it in. Worked great .. of course the bad side was I blew up the air box but that ia a WHOLE other sotry. Sounds like you have things well in hand.
Great Job.
Great Job.
Great Job.
Great Job.
Also as old man neri predicted I only lost a minimal amount of oil with one side jacked up.
And to Peter... good race eh? Can't believe the mistake that was made but good for Bob!
Thanks to everyone for the help and suggestions in the various posts.
bullit: Good job on the re-adjust - rotating the feeler gauge into place is how it should be done. Just that slight amount of movement, perfected with practice, makes the whole thing work.
Great race - what's with that pit-out light in Canada? Massa (who was brilliant yesterday going from last to 5th) missed it last year, and then Hamilton pulling the ultimate bonehead yesterday. Bad deal for Kimi, that could have actually ended up being a 3-car race to the finish...
