911 Forum 1964-1989
Erratic window operation...
Old May 29, 2008 | 11:47 AM
Marty916's Avatar
Marty916
Default Erratic window operation...
My driver side window has just started acting up. It goes up but has a problem coming down. I can toggle the switch a bit and it will start working again so I'm assuming it's a bad switch, however before throwing parts at this I was wondering if there are any other areas I should be looking at. Perhaps the motor, a relay(s), etc? I'm under the impression that when a motor goes bad it pretty much dies but I may very well be wrong. Any ideas? Thanks very much!
Old May 29, 2008 | 01:08 PM
Bob S's Avatar
Bob S
I think your right, sounds like a bad switch...
Old May 29, 2008 | 02:42 PM
Amber Gramps's Avatar
Amber Gramps
OOPS! I forgot to hit the post button....
Take the switch out and see if by-passing it helps. You sould be able to jump across the switch and get the motor to work.
I remember a thread about lighted BMW switches that worked well as a replacement.
https://rennlist.com/forums/showthre...t=BMW+switches
Old May 29, 2008 | 02:57 PM
Marty916's Avatar
Marty916
It was the switch. I just replaced it and the system came back to life. The shop told me to stick with the OEM switch as they have had a lot of problems with the aftermarket units failing. OEM was $21.00 (CT Automotive, Campbell California). Thanks a lot for the responses!
Old May 30, 2008 | 11:53 AM
Mike Murphy's Avatar
Mike Murphy
One of the best tools I ever bought was my $30 electrical tester. Whenever I was unsure which device in a string of 5 devices connected with 5 cables and fuses failed, the tester came to the rescue. If I saw 12V come to life with the tester, then I was pretty sure I could continue down the path until - sure enough - one of the components had failed the test.
Just something to consider if faced with this same situation again.
Old May 30, 2008 | 06:33 PM
dshepp806's Avatar
dshepp806
I changed ALL of mine out with new OEM stuff.......did it when (just) ONE went intermittent on me..won't worry about those again for a long time...done....next?
Best,
Old Jun 5, 2008 | 08:52 PM
Barry A. Waters's Avatar
Barry A. Waters
Marty916,
+1 on your shop's advice to go with OEM ONLY on these switches. I recently got two from a national aftermarket/catalog source well known to all and they were JUNK!
They were about $16.00 US each at the time and now they're around $14.00 with the tag "New Lower Price!". I wonder why... ;-)
Both gave me intermittent performance during the installation test phase and withing five minutes of being installed did a fine job in blowing the fuse on the controlling circuit.
The 'rocker' portion of both switches was very 'imprecise' in its movement and would actually move from side-to-side in its surrounding mount and would sometimes stick in both the UP and DOWN positions!
They went back to them with a full report and I DID promptly get my $ back so they handled it OK I guess... Thank goodness I only torched two fuses!
The OEM units are not that expensive and will give you no worries. Glad this was your issue - simple (with quality parts!) fix.
Barry
Old Jun 5, 2008 | 10:31 PM
dshepp806's Avatar
dshepp806
OEM, for sure.
