BROKEN SWAYBAR MOUNT!!!!
How do I FIX THIS????? PASS side rear sway bar mount is snapped.....Now what????
No worries mate, buy a new and improved one from wevo (about $80) and any shop can weld it in for you in less than an hour. Or if you know someone with a welder, even better. Easy easy fix, it's a common failure
ok cool.....its just scary when things snap off the BODY....
Yep, I read all about this problem, and sure enough, mine broke right off at my first DE even. Sounds bad, too, with all the clunking noise
An easy, routine fix., though.
Had it welded today....reinstalled sway bar which is actually a weltmiester rear sway....NICE. Has a model number on it....says...9070. I think 22mm in front and rear....Nice.
