OEM wipers for my 3.2 Carrera I just bought are not working!
I bought some new OEM wipers from Pelican, and I'm not that impressed. They leave water streaks while running, and the drivers' side wiper doesn't even fit completely on the windshield. Is anyone running a different wiper on their 3.2 Carrera that they recommend?
The Ancient One
Rennlist Lifetime Member
Same problem w/ the Bosch replacements. The left wiper has about 3-4" sticking into the air when they are parked.
At least they are fairly decent wipers on the areas they touch.
I've decided to refrain from driving the Porsche in the rain, so such trivial things don't really matter.
I had a same problem on driver's side wiper sticking into the air. In fact, I've yet to see a 3.2 or a SC with driver's side wiper fit perfectly (not stick out) when it's parked at the bottom. Like Dan, I don't drive mine in the rain, so I rarely use my wiper.
murphyslaw, I buy a lot of stuff from Pelican, but I buy my wipers from a local parts place such as Autozone, Advance Auto, Pep Boys, etc. Whoever has the 13 inch size. That way if they don't work properly, I take them back and they replace them. Pelican would probably send you new ones, but time and shipping gets involved. One way shipping would almost pay for one blade.
Weathergirl
OEM or OE? Big difference in quality for 993s, likely for the shorter 911 blades as well. OEM Bosch on top. OE Porsche box on the bottom. You really need the extra hinge to conform to the curved 911 windshield (same as 993).
![](http://www.rallystuff.com/images/993_wipers1.jpg)
RallyJon, what is the difference between OEM and OE in general?
Originally Posted by Spider911
All 911's from day one have the wiper sticking up on the driver's side. Been almost 41 years now.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Team Owner
AKAIK
oe - the actual original equipment your car came with . Can be obtained by dealer
oem - part made by company that made the part originally but may not be identicle.
Originally Posted by Droops83
This is true, but are you sure that your wiper arms are not switched? I have seen a LOT of 911s where the left and right side wiper arms are switched and they won't work quite as well this way. The arm that has the bend in it right before the part where the blade attaches goes on the right hand, or passenger side if your're talking a LHD car. The straight arm goes on the left (driver's) side.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
I just replaced the wiper blades on my wife's Acura MDX with Bosch ICON blades and am really impressed. They do not have the typical hindges that make a tight fit on the windshield difficult. When you take them out of the box the naturally bend to almost a semi circle and once on the windshield they fit nice and tight. I will look into using them when I need to replace the blades on my 911. I am not sure if they come in the proper lengths for our cars but definately worth looking into.
Originally Posted by murphyslaw1978
Interesting - I may have mine switched, since I did not notice any difference between the two blades. I will have to check this...
Yes, the blades that I ordered are the same on either side. So these must just be generic blades. I will look into the Bosch ICON blades...
---Chris A.
I checked the blades and noticed exactly what you mentioned above - the passenger side is the bent one, while the drivers side is straighter. But shouldn't they be switched? It would seem that the drivers side blade would adhere better if it were attached to the bend arm. After all, the bend curves toward the windshield...?
