Bringing steering wheel and shifter closer?
I have an '87 Carrera with a Momo Corse steering wheel and Momo hub, which of course is a common setup. I'd like to bring the steering wheel a few inches closer. Anyone have experience with an extension? I'm tall and sit with the seat way back, and I have to reach too far for the steering wheel. It should be do-able; race/rally cars have some pretty lengthy hubs.
Also, I need to move the shifter further towards me. I'm thinking of having the lever bent, but I'm open to suggestions.
Thanks,
Will
Thanks,
Will
Will,
My 928 has an extension that brings the wheel about 2" closer. Unfortunately, I'm 5'6". LOL
I would think you can get an extension from MoMo.
Good Luck,
Good Luck,
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Hi, I think a quick release from Smart Racing may do the trick. I had put one on my track car with the same wheel and hub you are using and it pushed the wheel back to me another 2"+/-. You can get the address and phone numbers for Smart Racing from the back of a Pano. Regards,
King of Cool
Will,
How's your seating position?
I'm not tall but I have my seatback almost an 90 degree angle (about 85 maybe) like you see in racing cars.
In my 911, my seating is quite good, shifter could be a little closer but it's ok.
In my 993, my legs are getting too short...
I know it might feel odd when you first test it but you get used to it and it really is the way you should sit when you drive a race/sportscar.
If you are already seated like that, then you need an extension... I just thought that maybe you are one of those who lean back like they were in a lounge chair or something
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
The problem with extending the steering wheel further back than the Momo extension provides is that the blinker and headlight levers will be too far forward to reach easily. I have this same problem.
As for the shifter, I also know what you mean. To get in fifth I have to practically come out of my seat. Shifting into fifth with a 5-point harness is out. I am planning to cut a wedge out of my shifter, bend the shifter back, and then weld it back together. I can't think of anything else.
Guys, thanks for the responses. I've located a couple of steering wheel extensions, one of them mentioned above by Scott:
<a href="http://www.smart-racing.com/ProdCat/Driver%20Comforts/Driver%20Comforts.htm" target="_blank">Smart Racing steering wheel extension</a>
Also sold by OG Racing: <a href="http://www.ogracing.com/catsteer.html" target="_blank">OG extension here</a>
Then there is a beefy looking extension that is stackable: <a href="http://www.racecarproducts.com/PAGE10.htm#721" target="_blank">Stackable extensions</a>
The first two are around 40 bucks, the last is 10. I'm going to order both and give them a try; I'll let you know what happens.
FF, I like to sit bolt upright, not leaned back like my son in his Jetta.
I'll also report back about the shifter modification.
Will
Will
I also have a Momo in my 911 and had to put a spacer in to move it closer to me. Since then I have found that Sparco makes wheels with different amounts of dish in them to avoid using a spacer. Just a thought for anyone who has yet to buy a Momo or wants to replace theirs.
