Key won't turn !
Key won't turn !
Hopped in my '86 coupe for a Sunday drive and...
The ignition key won't turn. No amount of jiggling and coercing seems to work. Tried both of my keys.
This happened once before ( last year), and a few minutes of jiggling worked).
Any ideas form the 911 community?
Try pushing in or pulling the key out slightly. Sounds crazy, but works for me. Sometimes I have to push the key in and turn at the same time to get it to work. If you still can't, sounds like it's time for a new ignition.
Searched on the Pelican forum and got a few tips.
Tugging the steering wheel to and fro a little worked. Apparently, cocked wheel can load up the wheel lock and affect the switch.
Also recommneded was a dose of WD40, which I didn't need.
Mine did the same thing before, everything was fine till I got back in to leave, key would NOT turn, no matter what I did, turning steering wheel left or right, jiggling key, pushing in, pulling out a little. It seems the lockout block had failed to reset when I turned ignition switch off and removed key. It was the block that prevents you from turning the key to the start position more than one time without turning key to the off position. I was lucky enough to be parked in front of a liquor store where the owner was a handyman, had a can of WD-40, I got some paper towels his can of juice and started to work on the switch. I stuck the tip of the key in just far enough to open the little cover then inserted the tube on the can and flooded the inside of the switch tumbler all the while bumping the steering wheel back and forth on the steering lock and then trying the key again. After doing this a couple of times, I heard and felt a little click at the switch, when I tried the key again, it worked fine, the blockout had reset. I now carry a can of WD-40 in the trunk. Have not had anymore problems with it doing that again. There was a lot of crap that came out when I flooded the switch, little metal specks, grime, grit, and dirt. I guess from just a lot of years of exposure and use. Good luck
I have the same problem with my 80 SC. I don't want to pony up the money to get it fixed right now, so I used powdered graphite with good results. I didn't have much luck with the WD-40, I think it's too worn. Good Luck.
