911 Forum 1964-1989
Oil sump plate drain plug drain plug
Old Jul 5, 2021 | 04:53 PM
moburki's Avatar
moburki
Default Oil sump plate drain plug drain plug
1978 SC doing my first oil change on new to me 911. Bentley says 31 Ft-Lbs. Start turning the torque wrench.. that does not feel right.. Stopped. Grabbed my non torque wrench to see how it feels. It just turns. D@*#&!!
Now, question is, is there an aftermarket sump plate replacement that has a good reputation? Or stock?
I really was looking forward to going for a drive
Thanks in advance,
Mo
Old Jul 5, 2021 | 05:19 PM
theiceman's Avatar
theiceman
Team Owner
yeah lots of billet plates but can be pricey, just grab a stock one, should be cheap, even a used one im sure would be fine
https://www.pelicanparts.com/More_In...VSVSI=790&fs=0
i even have a spare in case that ever happens to me. worth 25 bucks just t have one on the shelf just in case, even if i replace it again later with a better one.
Igooz's Avatar
Igooz
Trucker
So you are thinking that you overtorqued and stripped the threads on the plate? (You should know that you are not the first to do this.)
You can remove the plug again and drain the oil. (Up to you if you can catch it in a super clean bucket and reuse or not? Up to your comfort level in keeping the oil clean, etc.)
You can check the threads on the pan and the plug and see what has happened.
Pelican sells replacement for both.
Old Jul 5, 2021 | 05:22 PM
theiceman's Avatar
theiceman
Team Owner
i would hope there is no oil in it yet , but tie a rag to the steering wheel in the meantime, always good to have that reminder.
Old Jul 5, 2021 | 07:09 PM
moburki's Avatar
moburki
I would have hoped I would know better too. I had a bad feeling after putting 4 qts in. That's when I double checked with a ratchet. I thought even though the torque wrench never clicked, I was calibrated enough to go with it. I'm glad I checked in retrospect. Would have been worse if that thing backed out on me.
So the URO plate is of adequate quality? I have had hit or miss with their parts in the past. Seems like a simple enough part to reproduce.
Anyone have a different torque spec for this plug (Bentley says 31ft-lbs)? Pretty thin plate. But, the thread is large diameter.
Thanks for the replies everyone.
Mo
Old Jul 5, 2021 | 08:40 PM
Igooz's Avatar
Igooz
Trucker
iceman knows better than me...
And I am not buying/selling, but I have generally NOT had good luck with URO parts. Here is what Stoddard offers:
SIC10128600 Oil Sump Cover Plate Fits 911 90110128600 91110128600 (stoddard.com)
Old Jul 6, 2021 | 12:26 AM
Mark Salvetti's Avatar
Mark Salvetti
Mo
Bentley looks right, the Little Spec Book says 42 newton-meters, which is 31 ft-lbs. I have to admit, I've never used a torque wrench on the drain plugs, just tightened until it felt like enough.
Mark
Old Jul 6, 2021 | 01:24 PM
theiceman's Avatar
theiceman
Team Owner
i think of it as an emergency spare other than a long term solution. I would pick up a used OE one eventually at a swap meet.
some things i don't even use a torque wrench . Ive been doing oil changes for over 40 years. one or two good ougha doughas is good for me.
Old Jul 6, 2021 | 02:02 PM
moburki's Avatar
moburki
Same on the torquing oil drain plugs. But for some reason I was compelled to use a torque wrench this time. Won't happen again, I trust my well calibrated wrist..
Old Jul 7, 2021 | 06:25 PM
Igooz's Avatar
Igooz
Trucker
Nothing wrong with a good torque wrench. You may want to get your torque wrench inspected/recalibrated or upgrade to another.
And on the other hand, with these old cars, you may have had a gorilla work on it before you and had damaged the threads and you just did not know it. Was this the first time that you had tighten this particular oil pan plug?
Old Jul 7, 2021 | 07:19 PM
moburki's Avatar
moburki
Yup, first time. I think it may have been ham fisted previously. It was very, very tight. Either way, easy fix, luckily. I would have been heartbroken if it was in the case. Not a hard fix either, just can't make it new again. My torque wrenches are all good. New plate should be here tomorrow. Then, I can take it for drive with new blood. Oil looked good, but it was in there for a very long time.
Thanks again for the input,
Mo
Old Jul 7, 2021 | 08:51 PM
r911's Avatar
r911
Anti-Cupholder League
Just to check, did you use the torque wrench near the middle of its range? Or at the extreme low end?
Old Jul 7, 2021 | 10:34 PM
Mark Salvetti
Mo
This reminds me of my first oil change on my SC. I couldn't get the drain plug off the tank, so instead of making the usual mistake with a pan that was too small under the oil tank, I pulled off the S-hose and spewed oil all over the floor sideways.
The drain plug was on so tight I thought I was going to tear off the bottom of the l tank. I ended up having to use a Dremel to carefully cut between the drain plug and the washer. Sacrificed the drain plug, but once I cut through all the way around I was practically able to spin off the drain plug with my fingers. Luckily no damage to the threads or the sealing surface.
Mark
Old Jul 8, 2021 | 05:38 PM
moburki's Avatar
moburki
I have one wrench that puts 31 ft-lbs in the meat of it's range. 3/8 drive. Don't remember it's max off hand. I believe 75 ft-lbs before I switch to my larger wrench.
Old Jul 8, 2021 | 08:35 PM
r911's Avatar
r911
ok, this bolt may have been damaged by a PO
I'd clamp something in a vise and hang a known wt. 1 or 2 ft. from the pivot to check the torque wrench tho
