911 Forum 1964-1989
Oil sump plate drain plug drain plug
Old 07-09-2021, 12:52 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,111 Likes on 794 Posts
Originally Posted by Mark Salvetti
This reminds me of my first oil change on my SC. I couldn't get the drain plug off the tank, so instead of making the usual mistake with a pan that was too small under the oil tank, I pulled off the S-hose and spewed oil all over the floor sideways.
The drain plug was on so tight I thought I was going to tear off the bottom of the l tank. I ended up having to use a Dremel to carefully cut between the drain plug and the washer. Sacrificed the drain plug, but once I cut through all the way around I was practically able to spin off the drain plug with my fingers. Luckily no damage to the threads or the sealing surface.
Mark
i cant even imagine how much fun that would have been from under the car..
Old 07-12-2021, 09:57 PM
Spyerx
Spyerx's Avatar
Received 1,782 Likes on 1,085 Posts
off topic fact:
on the 914/6, the oil tank is drained by removing the hose on bottom. no plug. it's messy to say the least.
Old 07-13-2021, 07:23 PM
URO Support
URO Support's Avatar
Originally Posted by moburki
So the URO plate is of adequate quality?
URO Parts Engine Sump Plate 901 101 386 00-PRM is actually an improvement upon the original. We upgraded the material to stainless steel, but painted it black to maintain the original appearance. We've sold almost 200 so far with none returned, so they must be working for folks.
moburki (07-14-2021)
Old 07-14-2021, 12:54 PM
moburki
moburki's Avatar
URO is the one I ordered. Thanks for chiming in.
Old 07-19-2021, 02:16 AM
pmax
pmax's Avatar
Drain plug's a pretty hefty nut, 31 ft lb sounds fine never having used a torque wrench on this.
How about a pic of the sump plate ?
Old 07-19-2021, 11:27 AM
moburki
moburki's Avatar
The old plate with the compromised thread? I can get a pic of it. I saved it, don't know why. Yea 31 ft-lbs is nothing for 18mm (iirc) thread. I suspect someone before me overtaxed the thread.
Old 07-19-2021, 12:42 PM
URO Support
Given that the threaded area for the drain plug is the same thickness as the rest of the stamped plate, there's not a lot of material supporting the threads, so the threads in the plate would likely fail before the plug threads if someone grossly overtorques it.
Old 07-19-2021, 01:59 PM
moburki
moburki's Avatar
Yes, that was the failure mode. The magnetic drain plug was unaffected. Your sump plate fit up well and looks nice.
Old 07-19-2021, 02:09 PM
HenryPcar
HenryPcar's Avatar
Sometimes it is better off NOT using a torque wrench that is inaccurate. Torque value of 31ft/lbs needs a torque wrench within that range (3/8" size) to be on the safe side. Nothing worse than over-torquing some fasteners (i.e. aluminum) threads that you can't even retap them. I would rather hand-torque some fasteners than risking using an inaccurate torque wrench.
Quick Reply: Oil sump plate drain plug drain plug
