1983 911sc dies occasionally
I have a 1983 911sc. It runs great most of time but occasionally while driving when you let off accelerator & pushing clutch the car dies immediately. When this happens the rpm drops to zero immediately. It doesn't happen often but when it does it seems to happen a couple times back to back. The engine starts up immediately when letting out the clutch.
Team Owner
silver ignition coil ?
also check idle adjustment, sometimes you can turn it a fair bit before idle goes up, turn it until idle goes up than back it off until you reach proper idle.
Team Owner
Originally Posted by theiceman
not sure but i can tell you silver coils suck ... it may not be the answer but this is a generally accepted fact.
