Difficulty reinstalling distributor
Trying to reinstall the distributor body back into engine and it doesn't want to go past the new 'O' ring.
Every thing lines up to all the markings I have made before removing the distributor and the gears feel like they line up inside the engine, but it won't seat because of the seal. It goes as far as the seal.
The p/n is 91160210201 and it fits snug, just in case some one want to know. Engine is a RS.
Any tricks to get it to seat?
hi..well i did have similar problem back couple of years ago....I suggest to you get the green o ring...btw the old one was orange;-)
and one more thing..use if you have the old Bosch grease or the the new Sachs grease..
Ivan
Ivan
No Bosch grease. Wouldn't plain old VR1 oil do the job?
Hi..i had to google what is vr 1 ..oil right...not really ok but it will do.The ring you are using ..i do not know where it comes from and how long it has been in stock.So ,get your self the green o ring..
Ivan
Ivan
The 'O' is from the Porsche dealer so I don't think it is old. Anyway my Porsche mechanic said that is the ring they sent.
His tip was to take the rotor off and place of block over the shaft and hit it a few times. That indeed worked, so I am guessing it might last even longer than the 'green one' because it is much tighter.
You need to put grease on it. Get it started, then take a long thick screwdriver and a mallet and tap it in using the bracket to strike on. Gentle taps.....it will get it past the o ring.
