SOUL | 718 GT4/Spyder Exhaust Development
#286
Received my over axel pipes last week and installed them on my Schmid Motorsport exhaust by my local Porsche mechanic. There is a huge improvement and I’m loving the sound, especially the interior sound. The “drone” at 2000-2500RPM isn’t much different to my stock PSE and similar to what I heard on 991 GT3’s. I’ve also installed the valve control unit from Schimd Motorsport and love the fact that I can drive aggressively with the valves closed. Thanks Soul for all your help and great service! I’ve attached a video. Cheers!
https://www.youtube.com/watch?v=-4igN7FPcG0
When valves are closed do you get a very subtle drone between 2000 and 2500rpms? (Similar to stock muffler)
Soul Performance (09-21-2020)
The following 2 users liked this post by alexk79:
DocMo (09-21-2020),
#288
Basic Sponsor
-Mike
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
johng@soulpp.com
jwheel@soulpp.com
#289
Basic Sponsor
So even with opf’s on the car a valved x pipe will drone? Interesting. How much louder is your muffler gonna be than the stock one? PSE is too quiet with the valves closed. I went with the kline opf deletes because they have built in mini silencers but was looking for a more aggressive rear end because i dont like the transition from valves closed to open and almost always end up plugging the vacuum hoses. One option is a valve controller (or dsc if they ever add that functionality) or a resonated x pipe like your race exhaust. Only problem is now i need a double inlet rear section that would fit to the over axle section with the double outlet design. And your race exhaust only has a different over axle pipe design (single tube).
Man, can't hide from Facebook haha. Thanks very much!
#290
I've been meaning to add to this thread for a bit. I've had my Competition Headers, Over Axel Pipes, and Race Exhaust with Resonators installed for about a month. All I can say is LOUD! I'm sure this isn't most folks setup, but figured I'd share my impressions. The sound is raw, aggressive and at home on the track. I'd say around town it can be a bit much. If my car weren't 80% track I'd opt for a less aggressive setup. The drone zone of 2100 to about 2800RMP is real, but tolerable. I took the car on a 4-5 hour drive up to Watkins Glen 2 weeks ago and with the windows up and radio on the cabin noise isn't bad. On track the setup is amazing. So impressed with what the folks at Soul have done John is 1st class all the way. Here's a little video on track to give you a sense of the sound. Enjoy.
#291
#292
#293
NJMP Lightening Hotlap - Soul Exhaust
Awesome! I'm sure the audio doesn't do justice to the sound.......this is the setup I'm going for.
Questions....what's your solution to run catless without having the CEL ?
#294
In terms of CEL you really don't have many choices. I spoke with John at Soul about this as well. Your choices are live with it and plug in a port scanner to confirm the code every once in a while. If you have a bluetooth port reader (e.g Kiwi 3) just leave that plugged in and check it on your phone (my current approach). John mentioned you could get it coded out, but right now that requires a bench tune which. I'm not ready to go there yet. Will probably do that when a tune for this setup is more readily available. I hate looking at the CEL, but I like the sound more, so a choice you'll have to make.
#296
You are correct, the audio does not do it justice. The sound can only be experienced. Cold start is crazy. I've tried to record that but it just doesn't capture it accurately. I spent quite a bit of effort to get the recording about to be somewhat decent. This was from an external microphone mounted just below the license plate. I had to take the audio down quite a bit even for this clip.
Thanks for the info....how about using one of those spacers with a mini-cat for the second O2?
On my 981 GT4 with race headers I did the COBB so the CEL was a non issue....I do prefer to flash or do the COBB AP to having to reset the CEL all the time, plus you get a few more HPs.
#298
If you have an exhaust or engine problem the dealer (if it's not a friendly dealer) could argue that the over axle pipes had something to do, but they can't denied work on anything non related.
This is one of the reasons to develop a good relationship at your Porsche dealer, not only with sales but also parts/service department.
But lets be honest here.....the chances an exhaust mod on these cars could create a warranty problem are very small....hopefully these new 9A2 Evo engines will be as bulletproof as the previous 9A1.
Soul Performance (10-07-2020)
#299
#300
Does the stock exhaust just have the one cat per side in the header, or is there another one behind that?
Ron
Ron
