718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
JCR 718 GT4 v2.0 - PROJECT THREAD
Old 02-27-2023, 03:07 PM
  #76
TDT
TDT's Avatar
Originally Posted by motoring
Did the track width change with the switch to centerlocks? I have heard that the track is slightly wider on the gt4rs, and was wondering if that was entirely in the difference between the CL and 5 lug hubs
Pretty sure this is primarily down to the fact that the 4RS just comes with more shim as standard.
But the team will confirm.
Old 02-27-2023, 03:14 PM
  #77
jwr9152
jwr9152's Avatar
This video explains the difference between the GT4 and 4RS pretty good. Skip to the 4:28 mark to see them talk about the width difference.
Old 02-27-2023, 03:27 PM
  #78
TDT
TDT's Avatar
It’s the shims…
donR (02-27-2023)
Old 02-27-2023, 06:08 PM
  #79
rubber_ducky
rubber_ducky's Avatar
Originally Posted by JCR-Porsche
One of the main reasons for going with the centre lock conversion on our car is to enable us to run the factory 718 GT4 RS magnesium wheels which offer a significant weight saving over even the lightest of aftermarket 5-lug options. Shockingly at a reasonably comparative cost too, once all things are considered
Can you elaborate on this comment? What are you comparing this to… aftermarket 5 lug magnesium (or carbon fiber) wheel options?
Old 02-27-2023, 06:50 PM
  #80
donR
donR's Avatar
Very much enjoying this GT4 RS conversion build! I dare say when you are finished this car will be driving better than the OEM GT4 RS especially with the MR suspension kit. I am wondering if you have any data on the stock 4RS versus MR spring rates? Is there much of an increase or change at all? I believe the stock GT4 spring rate is relatively low by comparison. For utlimate brake conversion you already have the Surface Transforms Carbon Cermics but wondering if there is a light weight caliper conversion you could consider like the AP Racing Pro Series caliper?
Old 02-27-2023, 10:10 PM
  #81
mprog
mprog's Avatar
You know I’m interested !
Thanks,
- Jahan
Old 02-27-2023, 10:45 PM
  #82
nothingman
nothingman's Avatar
INSTALMENT 03 // EXHAUST
We opted to install the combination of our Inconel Race Manifolds and Inconel Link Pipes (Race Catted) onto the 718 GT4 and retain the factory rear silencer SHOP PRODUCT HERE
The factory manifolds are unequal length and manufactured from mild steel and feature extremely restrictive cats.
The JCR Inconel Race Manifolds in comparison are manufactured from Inconel 625 material, featuring equal primary lengths and without cats which allows us to optimise runner lengths within the space made available.
JC
By placing the cats further back in the exhaust where the factory OPF filter is/was, are you able to extend the life of the cat by running it a little cooler in a track environment? I, along with a few others I have read about, have damaged aftermarket HJS HD200 cats in exhausts that are right off of the header due to hard charging on tracks with long straights and I'm looking for a solution that can take the abuse. How do you extend the secondary O2 cable back to the new cat area?
Old 02-28-2023, 04:44 AM
  #83
JCR-Porsche
Basic Sponsor
JCR-Porsche's Avatar
Identical to stock
HRE R101LW would be our choice. By the time we purchased, shipped and paid import etc it was only ~£1500 for us to buy OEM Magnesium wheels from Porsche and all of the associated Centre Lock parts
Yes we're working on a direct replacement calliper, completely bespoke. Stiffer, lighter and slimmer than the factory calliper. Expecting that we will have the parts on the car in the next few months for the first phase of testing
We've never encountered any issues with HJS cats. A cat gets a much harder time on a turbo application and we run the exact same cat on our 992 Turbo and 991 GT2RS exhaust products with zero issues. For the repositioning of the Lambda sensor we supply an loom extension
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
  #84
DrainsWalletsFast
DrainsWalletsFast's Avatar
Originally Posted by Hinz Motorsport
The idea for GT4 models would be to run 380 discs to clear 18" wheels. This total package could save around 60lbs of unsprung weight (most of which is also rotating mass as well).
I bought a GT4 but was bummed it had regular iron rotors with the red calipers. This definitely sounds intriguing depending on the cost. I was already eyeballing used PCCBs or new ST rotors as a possible change either soon or after I run out of the standard brakes. After putting stock wheels on a car that had lightweight wheels come off and feeling the difference it made, I'm now very motivated by reducing unsprung and rotating mass.
Yeah I'm actually quite curious the cost and also the level of weight savings.
Old 02-28-2023, 06:58 AM
  #85
JCR-Porsche
Basic Sponsor
I'll confirm all weight savings in a dedicated post soon. It's pretty significant
JC
Old 02-28-2023, 09:48 AM
  #86
jmartpr
jmartpr's Avatar
Received 1,477 Likes on 918 Posts
Identical to stock
Hi Jonny...are we positive on this? No change in the dimensions between CL and 5-lug hub?
BTW...do you know the weight of the OEM Mag wheels?
Old 02-28-2023, 10:03 AM
  #87
JCR-Porsche
Basic Sponsor
Positive, the bearing assembly is the same stack height and bolts directly to the upright in the same way as stock. Any difference that Porsche quote on track width is due to shim and/or upright
The Mag wheels are identical size to stock GT4 wheels too, width and offset
For the weights I need to get around to compiling all the weights and ill share. It's pretty significant and you can certainly feel it when driving the car, even at normal speeds
JC
The following 2 users liked this post by JCR-Porsche:
TDT (02-28-2023), thomas_gt4 (02-28-2023)
Old 02-28-2023, 09:37 PM
  #88
Bents
Bents's Avatar
Identical to stock
1,500 or 15,000?
Old 02-28-2023, 09:46 PM
  #89
Westcoast
Westcoast's Avatar
Received 4,702 Likes on 2,736 Posts
Originally Posted by Bents
1,500 or 15,000?
Jonny might be referring to the cost difference between the two types of wheel packages...
Old 03-02-2023, 11:40 AM
  #90
JCR-Porsche
Basic Sponsor
1,500 or 15,000?
Sorry yes I was, it was £1500 more (I left that part out) oops!!
JC
Quick Reply: JCR 718 GT4 v2.0 - PROJECT THREAD
