Dundon 718 GT4RS Development Thread. Input wanted!
#46
So the OAP not only have the GPF but also a second cat? What a way to choke this engine......
#47
992 GT3 + 3RS just has bigger cat units and then OPF filter directly after it in one combined unit.
UncleDude (01-10-2023)
#48
Guess it was necessary to split cats into 2 parts to meet the emissions targets within the thermal and packaging constraints. The big boy engine pushes more air faster than casual 4.0 so needs space and volume to get it out effectively.
But the secondary o2 sensor for cat efficiency is between the 2 cats....so if you want to properly measure cat efficiency it would be after the second cat.
#49
#50
Has anyone tried to hack the stock back box and somehow blend the banks? That might be the last frontier!
#52
To boot, the decibels out the exhaust tips will amped up, again, probably even more than Dundon achieved with the GT4.
The cabin acoustics of the RS are already epic.
I suspect we will hear all the same stories about trying to cross a bridge too far . . . where enthusiasts like me tried to get a rear box solution to match up with the Dundon headers/OAPs, only to find mind-boggling drone is the price for improved tone.
Headers/OAPs with OEM rear box is most likely going to be the best solution available. . . if one is committed to Dundon.
Avera
#53
Does does the OAP need to have a cat to not throw a CEL?
#54
Wait, the GT4RS as 2 sets of cats and a set of OAPs? Didn't the GT4 only have just 1 set of cats a set of OAPs? I want to remove that butt plug of the cat/OAP going to the rear muffler and some good flowing headers. Those 2 things will improve the sound and give the car a bit more power.
#55
The following 2 users liked this post by BabyNSX:
Avera (01-10-2023),
usctrojanGT3 (01-14-2023)
#56
#57
#58
That's what Dundon said on their Instagram video.....when you see the OAP up close on the video it looks like this could actually be true, It looks like it has two sections. There's your missing 10 hp.
#59
The dundon video didn’t say this and I haven’t seen any information that 4RS has different set up for various markets?
If you have could you give a pointer or maybe someone can confirm sensor locations on their cars.
992 RS has been adapted since 992 GT3 with larger car and smaller OPF matrix and doesn’t use temps sensors anymore, instead taking that data from the map.
Maybe we discover that 4RS is adapted in the same way and monitors via map rather than sensor reading?
#60
Have we seen this detailed/confirmed?
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1300x969/pasted_from_clipboard2_b367334fc38f370adef15e202abf700157f2e51c_2a864c8d1f0e167431b2c7ae5fb92466138d9e38.png)
enduro (01-11-2023)
