PIWIS 3 Coding Retrofit and Feature Request
#511
Hey @West Coast can you edit the OP and put in an Index of sorts?
I compiled this list based on what I see in the thread (I think I got them all...)
WOW! You did all of the work for me!
Yes, tomorrow morning when I am in front of the computer I can make the edits... I had plans to it this week, but home plumbing issues have precedence when it involves toilets.
I don't think I washed my hands this many times even during the beginning of Covid!
I was waiting for you. Thanks @daaa nope
Incredible continuing effort by @718socal and those contributing to this thread really show support for the Rennlist community, well done!
#512
I was happy to help by adding the index to post #1, thanks to @daaa nope for putting it together.
Westcoast (04-14-2023)
#513
I got two issues:
1. Wing does not come out, dash warning when 80 or so is reached.
Most likely in the cluster
2. I have the Enabling code for SportChrono Plus, it is in VO, I even coded a button for Sport Plus in the BKE module. Does the Enabling code have to be entered in the PCM? I don't have that working yet.
Bonus Question: My domelight is dead. Bought a used one, still dead. There is power to the plug. The entire assembly does not show in PIWIS. It works on LIN Bus. I checked all the fuses but nothing tested as popped. It stopped working when I did a wire tab on it. Probably shorted it. Never going to use those again. Also on LIN Bus is the element with all the switches and they work.
#515
#516
I got two issues:
#517
Try to run the job to activate the wing. There are a lot of options in the Drive Links Checks. As far as the Sport Chrono, you need to look at all the modules that will be affected. Go to each module and start Manual Code but don't click thru the end. It will list each option that can be added. Once you find all the modules needed for coding run Auto Code. I tried to reassign the buttons in the BKE module but was not successful. Where did you get the individual button?
I bought the switch element on ebay that had that button included. You can easily open the unit up and switch the buttons around to locations you want. Call me about the coding for it. I have changed it several times. This is probably the only thing I have done that did not brick the unit.
718socal (04-17-2023)
#518
Does anyone have an old version of PIWIS 3 or even the last PIWIS 2?
I need the Power Steering Control Unit flash file. PIWIS 3 loaded the wrong file and I have no power steering. The file I need, based on my last working VAL. I can post the file name if there is anyone with these older PIWIS versions.
#520
I don't know the file name, just the software version. I need software version 2700 for the power steering system. The file name has EPS in it and probably 2700. The only file in PIWIS 3 is sofware version 1310.
This wrong file name is FL_9x1_EPS_99161814704_1310_74_container.pdx. The needed file should be something like FL_9x1_EPS_xxxxxxxxxxx_2700_xx_container.pdx.
Danke fuer deine Hilfe.
#522
I wonder if this thread should not be in the main 718 forum, not just the 6 cyl forum?
It's a very important thread, perhaps one of the most important on this site
#523
Top Remote Operation
Ok, so I programmed the top to open via the remote. It worked, but the windows remained partially down, which is potentially problematic when you are raising the top remotely. I'm supposing the last two circled items will make them close. I apologize if this is mentioned in this lengthy thread someplace. I will change nein to ja and report back
#525
Which button on the key will open and close the top after this is coded?
The ROW cars have an extra button on the key for the top.
