718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
992 GT3 PDK shift knob in PDK GT4
Old 05-28-2022, 02:59 PM
  #46
nothingman
nothingman's Avatar
Originally Posted by 911BOSS
This maybe obvious, but can you please explain how the new PDK **** attaches to the shifter rod in the car? I know on the existing PDK **** you twist the collar at the base and pull up. How does the new GT3 **** go on and off and end up secure since the leather boot covers the area where the old twist collar would be. Thanks.
It's not obvious, at least in way I can easily explain. When the **** is pushed all the way down on the shifter rod, something up inside engages and clicks - the **** taking hold of the rod. When this occurs, the shifter button on top becomes proud instead of being recessed. See the photos below for a visual.
Zeus993 (06-01-2022)
Old 05-29-2022, 10:19 PM
  #47
911BOSS
911BOSS's Avatar
Thanks for the info. So then that begs the question how does it come off? Do you think you keep in Park and press the button and just pull up?
On a side note I tried to order one and the part is backordered until at least July right now.
Old 05-29-2022, 10:39 PM
  #48
nothingman
nothingman's Avatar
If I recall, the black collar beneath the **** also turns and locks it in. You have to turn the black collar before you can pull the **** off.
6-8 weeks is the standard timeline to get these parts. They're not usually in stock.
Old 05-29-2022, 11:51 PM
  #49
Super Stroby
Super Stroby's Avatar
I have the GT4RS parts coming from Germany. I'm sure its the same process except swapping the boot. I'll report anything different.
The following 3 users liked this post by Super Stroby:
911BOSS (05-30-2022), LooseNut (06-08-2022), N11g (06-20-2022)
Old 05-31-2022, 08:24 PM
  #50
Sekiro
Sekiro's Avatar
thx to OP I'm now doing this mod to my 991.2 GTS. However I ran into a little problem, I can't disconnect the hazard light/door lock buttons from the car. any tips on unpluging it? Should I just bluntly pull it off with force?
Old 06-01-2022, 09:43 PM
  #51
N11g
N11g's Avatar
I used GT4RS ****, just followed the OP's instructions, and did not have any issue putting it in. The new **** looks simpler and way better than stock. Much thanks nothingman!
Sekiro, for the button assembly, just use a flat screw driver to slightly press on the two little "*****" on the shorter edges of the button assembly (one at a time is fine). Good luck.
Old 06-02-2022, 02:12 PM
  #52
ramans
ramans's Avatar
Do you have the part numbers for the GT4RS **** for others to do this as well please?
Old 06-02-2022, 08:13 PM
  #53
N11g
N11g's Avatar
Post #35 - copy&paste for you ....
Suncoast now has GT4RS PDK shift **** and boot.
I ordered a set (Black/Arctic Grey) from a Canadian dealership (Back ordered/No ETA). And here is its part #: 982-713-120-A-P02, and for the plastic piece: 991-553-651-01-A05
Old 06-10-2022, 01:03 PM
  #54
ragerard
ragerard's Avatar
Default GT4RS **** in a PDK GT4
Just to be sure I understand. If I order the GT4RS shift **** assembly for my PDK GT4, do I also need to order the GT4 manual boot? Or can I just drop in the GT4RS **** and boot. I know the stitching on the RS boot is limited, but I can live with that.
Old 06-10-2022, 01:18 PM
  #55
nothingman
nothingman's Avatar
You only need the GT4RS PDK shift **** assembly. This thread was written before the GT4RS solution was available, so we had to combine parts with the GT3 PDK **** and GT4 manual boot.
Old 06-18-2022, 03:04 PM
  #56
Super Stroby
Don't forget the console trim. The GT4RS part still doesn't come with the manual console trim.
Old 06-18-2022, 05:48 PM
  #57
Super Stroby
For a little bit of extra resolution on how to get the collar off without breaking anything.
Its hard to see but there is a slot in the middle of the inside part of the clip when the collar is in the "locked" position.
If you don't have three arms like me pry each clip open and use a zip tie to slide under the clip and into the slot now holding up the clips on both sides.
Now that you have the zip ties in it won't come out because they jam while inserted and pulling down on the collar. One thing I found out is the collar as a "locked" and "Unlocked" cam. While the zip ties are inserted roll the collar to its unlocked position (clockwise). Once unlocked pull the zip ties out and then the collar slides down the shifter.
Close up picture of the slots on the shifter showing how it needs to roll before being able to slide off.
The following 2 users liked this post by Super Stroby:
chriswd62 (06-21-2022), The Pinkoboe (06-18-2022)
Old 06-19-2022, 06:27 AM
  #58
ragerard
ragerard's Avatar
Did you order it direct from Germany? If so, can you share the source and any details on the order.. I'm in France for another three weeks and it would be easy to get one sent to me here.
Old 06-19-2022, 06:38 AM
  #59
ragerard
ragerard's Avatar
So I'm sure, that's the little $18 piece Suncoast calls Console trim (Manual Transmission)SKU991553?
Thanks again.
Super Stroby (06-20-2022)
Old 06-20-2022, 07:18 PM
  #60
Super Stroby
My SA ordered it from the parts department and there is no stock of this part in the US as the car still hasn't made it here yet. I would drop by the local Porsche dealer close to you and order it. Its pretty small and will fit in a carry on. Yes that is the correct trim part.
Quick Reply: 992 GT3 PDK shift knob in PDK GT4
