Starting my GT4 “Tool Box”. Where do you get this stuff?
#31
Just watch out or you can get to Level 5 (or higher) before you know it, But it's a good problem to have
I don't have Matt's obsession or bank account but there are 6 fully loaded cabinets to the left of this picture with years worth of tools, parts and chemicals and the old school red Craftsman tool chest in the picture started everything. When I got it I never figured I could fill it, that didn't last the first summer 30 years ago.
Oh, I've also cleaned up the garage since this picture, it was making me crazy with all the clutter.
Driv200 (05-06-2021)
#32
For what it's worth, I just did an oil change with quickjack. I took out the 2 outermost fasteners that attach to the 3rd (middle) underbody tray before putting car up on quickjack. After that, put the car up on both the short and tall rubber blocks (you need the clearance for the panel to slide out; learn from me to save a step!). Then, the underbody tray is not hard to take out with quickjack. It's not a big pain, just need to know what to do and it'll be ok.
#33
How did you get enough clearance to put the car on the quick jack with BOTH the short and tall rubber blocks? I have to use the short blocks, and even then there's just enough space it under the car when the car is on the ground...?
I tried this approach and just couldn't get the panel off.
#36
Driv200 (05-10-2021)
#37
I have a quick jack, but after finding that it makes taking the aero off a pain, and the fact that I’m only doing brakes, oil changes, and sway bay adjustments myself, I’m selling it to a friend and getting Rennstands by SafeJack. The QuickJack is awesome, but it takes up a lot of space when not in use and like I said, it makes getting aero off a pain in the butt.
Rather than the electric or cordless impact gun/ratchet I recommend getting a reasonably sized compressor and air tools. The compressor will come in handy for a host of other things and air tools last forever. For the socket, any impact socket will do, just wrap the outside with a layer of duct or electrical tape and you're good to go. Most impact socket rim damage is user error
#38
Thanks for starting this thread. I've been wanting to compile a list of new must-have items but my energy for this is being sapped by the stop-sale monster.
The purpose-made jack pads might be a better option (I don't know), but I purchased a half dozen hockey pucks over a decade ago for less than $2 apiece, and they've served very well in conjunction with an ordinary floor jack. They fit right in the steel cup, and are made of extremely hard rubber that to this day seems as durable as when new. With the weight of the vehicle on them they are not going anywhere, at least in my experience.
#39
I should have taken notes after watching Obsessed Garage. He uses certain tools and things I need for my at home DIY fun.
He mentioned there is someone on Rennlist who makes jack pucks!
Soncoast Porsche is where I can get the oil plug key?
What socket is recommended to protect wheels and get lugs/bolts off.
Wheel guides?
PCCB rotor protectors for wheel swaps?
TPS sensors for 2nd set of rims?
Summer weight / track engine oil?
Wheel guides?
#41
Some floor jacks already come equipped with a good rubberized jack point built into their design. Schwaben from ECS. More expensive, but you get whet you pay for. I know what I want holding up my car when I am changing from street to track wheels. The pucks with the oblong chassis attachments are nice too, that way you don't have to crawl down on your knee to line up the jackpad with the proper jack point.
#42
Close to the same exact structure just colored red with a Schwaben logo
The following 2 users liked this post by 4carl:
CaymanMatt (05-16-2021),
Frank Torres (05-16-2021)
#44
I've had this or it's predecessor for more than a decade. It's light weight and perfect for taking to the track if needed to check tires or change brake pads. Would I use it without jack stands to crawl under a car? No, but properly deployed it's worth considering!
