Track day prep recommendations
As I was writing this up to answer some questions on a PM from an individual, I realized that I've done this at least several times now, so instead I'm making this a post that I can point people to. This applies to both the 981 and 982 GT4s as we've owned both. I hope it's helpful ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Disclaimer: The GT4 is my wife's track car (she's experienced and fast, 30-40 track days/year, and she instructs at a number of local clubs, PCA National certified instructor, MSF-II certified instructor). I drive a 981 GT4 Clubsport at HPDEs, but I do try to drive her car every so often. Our experiences with tires may differ from yours due to experience level, driving style, track surface, temperature, etc. - so take with a grain of salt. YMMV.
Tires: we use Bridgestone RE71Rs on our GT4, 265/35-19 front, 285/35-19 rear. They seem to last anywhere from 25-35 sessions/heat cycles, depending track temperature and how abrasive the track surface is. The thing I like about these tires is that they are consistent throughout a session (I typically get my best times at the end of a session) as well as throughout their life. We run them until we cord them – they don’t tend to heat cycle out (but it does happen). We run them at 33 PSI front, 34-35 PSI rear hot.
Why not Hoosier R7s? In my experience, R7s are great for about 8 heat cycles, then "OK" for about 8 heat cycles, then they fall off a cliff. I'd say the RE71R's grip level is typically above the middle 8 heat cycles, so on average they're way better.
You'd be better off going with "real" racing slicks, like Pirelli take-offs, which you can typically find for about $125/ea. Yes, sometimes you'll end up with a set that isn't very good, but most of the time you're way ahead on the performance/price curve. On the Clubsport I run Pirelli DH and Yokohama ADVAN A005 (medium A60 front, hard A80 rear) take-offs for slicks, Continental EC-WET for rains (but these are no longer available).
That said, you need to be aware that running slicks means more wear and tear on the car. The "Driving on the race circuit" booklet you get with your manual set specifically says "Do not use slick tires" on page 3. There is evidence that this is a real warning; the service lives and maintenance intervals listed in the technical manual for the Clubsport lists the following:
Note, with the amount of camber we ended up running up front, if I had to do it all over again I would probably change the offset on the front wheels to +45 to push them out 9 mm. I would also tuck the rear in a few mm, say go to +46 offset to provide more rear fender clearance. That said, the specs I outlined above are tried and proven.
Suspension: all of these tires like a lot of camber to wear properly. We run the following nominal suspension:
Front:
- Drive shafts: change every 5000 km
- Crossbeam and braces: change every 7000 km (this is essentially the cast aluminum subframe under the transaxle)
- Wheel hubs: change every 10,000 km
- Rear hub carriers: change every 10,000 km
- Front: 19x9”, 5x130 bolt pattern, +54 offset, 71.5 mm wheel bore
- Rear: 19x10.5, 5x130 bolt pattern, +43 offset, 71.5 mm wheel bore
- Front: -3.9 degrees camber, 10.0 degrees caster (factory spec), 0 to 0.1 degrees toe out each side
- Rear: -2.7 degrees camber, 0.1 degrees toe in each side
- Ride height: as low as you can go without causing a major headache for driving it on the street or loading on a trailer. Because the front splitter on the 982 extends much farther than the 981, the ride height is about 10 mm higher than before.
- The car is corner balanced but because of all the aero on the new GT4, we prioritized making sure that we kept the rake of the OEM setup. Measuring at the jack points (yes I know this is not where you're supposed to measure), the rear jack points were 11 mm higher than the front.
Front:
- Camber plates (race design)
- Thrust Arm Bushing (might be optional – depends on how much caster gets moved away from ideal when dialing in camber) + spacers for thrust arm
- Monoball end (longer LCAMBCUP ones needed for the increased camber)
- Front tie rod (longer 991.008.CLAMP.LONG needed for increased camber)
- Front drop links (for adjustable zero pre-load on the anti-roll bar)
- Toe control arm (needed for increased camber) + toe link locking plate (optional; removes the eccentric bolt which can come loose)
- Rear drop links (for adjustable zero pre-load on the anti-roll bar)
- Non-cup monoball lower control arm ends (optional, not needed to get to the camber spec but removes the slop of the OEM bushing)
- Spring upgrade kit (optional, but we found that they helped with tire wear and I thought the stock springs were a bit soft on track)
- Cobalt Friction now has brake pads for the GT4 (and GT3) (I’ve been working with them to develop). The XR2 (front) and XR3 (rear) compounds are fantastic.
- I would recommend replacing the OEM rotors when they’re done with AP Racing rotors. They last much longer, are cheaper than OEM, have better feel, and actually help your brake pads last longer since they’re harder.
- Front rotors – replacement rings are $399 each
- Rear rotors – replacement rings are $399 each
- BTW I have an extra set of front hats that I'm willing to sell. PM me if you're interested.
- Front: AP Racing by Essex Radi-CAL Competition Brake Kit (Front 9661/394mm)- Porsche 981/718 GT4, Cobalt Friction CRB-XR2-AP19-18.0MM pads
- Rear: AP Racing by Essex Radi-CAL Competition Brake Kit (Rear CP9449/380mm)- Porsche 981/718 GT4, Cobalt Friction CRB-XR3-AP2-16.5MM pads
- Wheel stud conversion kit
- If you're keeping the OEM brake kit, get these.
- Brake caliper stud kit (62 mm front, 85 mm rear)
- Brake line bracket stud kit
- Rollbar: CMS or Cantrell; there are other options
- If the car you purchased has the lightweight bucket (LWB) seats:
- Sub strap mount: CMS (as part of the roll bar order) or Cantrell
- Harnesses: Schroth Profi 2x2 Porsche GT4 6 point (the lap belts attach to the LWB)
- The passenger side LWB seat will require modification for the sub-strap; instructions are in the 981 GT4 forum somewhere
- Don’t forget to get a forward head and neck restraint like HANS, Simpson Hybrid S, or Necksgen
Last edited by ski35off; 01-30-2021 at 12:42 PM. Reason: typos, added AP Racing BBK info
You'd be better off going with "real" racing slicks, like Pirelli take-offs, which you can typically find for about $125/ea. Yes, sometimes you'll end up with a set that isn't very good, but most of the time you're way ahead on the performance/price curve. I run Pirelli DH and Yokohama ADVAN A005 (medium A60 front, hard A80 rear) take-offs for slicks, Continental EC-WET for rains (but these are no longer available).
Front:
Wheel and brake caliper studs: (optional, but because you’ll be removing wheels and brake calipers to change pads fairly often, I would recommend it):
Front:
- I’ll need to check, but I believe I have extra hats that I could sell you, then you’d just need the replacement rings (and hardware kit). I’d sell for $500 each axle (I’m pretty sure I have fronts, but not sure about the rears) if you’re interested.
- Don’t forget to get a forward head and neck restraint like HANS, Simpson Hybrid S, or Nexgen
Thank you for the post. I had been reading on the 981 forum and had not seen anything this detailed on the 718 forum. Excellent detail. Thank you
This is excellent info - thank you!
What tires are you planning on going to, now that RE-71s are disappearing? And what size(s)?
So many of the other tire threads are from 2016 and their recommendations are no longer valid.
Thanks!
Thanks!
Here it is: https://rennlist.com/forums/gt4/1196...continued.html
The original post is from last May, but it continues up until last week.
Also this: https://rennlist.com/forums/718-gts-...l#post17134048
+1 on this....there's a sticky on the 981 GT4 forum about this with lots of info.
I'll find the thread...
Tire rack has them on "Closeout" and Discount Tire Direct only has them in 2 sizes. They happen to be the proper sizes for GT4 20" wheels, but that's it. No 19s. Did you buy them from them in 19s? Maybe you bought their last ones...
Have you test fit the wheels on your car yet? Assuming the wheels work offset/caliper clearance-wise, it depends on the tire. The recommended rim width range for the 255/35R19 RE71R is 8.5-10", so I think you might be (literally) stretching it there. You might be better off with the 245/40R19 (8-9.5"). Range for 285 is 9.5-11", so you should be OK there.
245/40 makes sense, if I can find any. [EDIT: Michelin doesn't make a MPSC2 245/40 19R] I'm trying to stay clear of MPSC2s just because they're so expensive and I've had them heat cycle out on me before the tread disappears. Don't last as long as I want them to for that price. But if RE-71s become unavailable, I have a feeling MPSC2s are it!
I'm also contemplating jettisoning the 19s and just using MPSC2s on the stock 20s all summer for street and track. But I worry a bit about rain in that case. I've run MPSC2s in heavy rain on track and they were surprisingly good, but that was in a Carrera 4S...
Outstanding post. You pretty much covered it all.
I take it by your call sign and living in Woodinville that you all get up to ski at Steven's Pass. Grew up in Seattle many moons ago. Wish I lived an hour away from skiing.
