Dummy GPF Delete OAP DIY “Big Genitalia Mod”
#256
From a manufacturing standpoint build it to the toughest standard in one configuration is easiest, rather than build to each nation/region.
Avera (11-04-2022)
#257
I've heard both Euro spec and 'USA' spec in person, the Euro one is very toned down comparatively.
Avera (11-04-2022)
#258
Avera
#259
The coating doesn't change the sound, the comment regarding sound was that both the EU and NA GPF pipes have the same ceramic matrix and therefore sound characteristics.
#260
Yep, I am onboard with what you and @TXshaggy have shared . . . based on what you have each shared, it makes perfect sense to me that the EU and NA exhausts would sound exactly the same.
The part I find perplexing . . . how this notion that EU vehicles sound 'quieter' or 'muted' because of the GPF has not only been propagated, but is ubiquitous throughout Porsche and BMW forums, YT, etc???
Avera
#261
I think it’s great that people are still doing this.
Little update, I helped a new friend swap his Akra OAPs for my gutted OAPs last week (AutoX issue, tho still not 100% legal) and we both concluded there was no audible sound difference to our ears.
#262
Done with mine, took about 4hrs. Helper came in handy to help line them back up when putting them back on. I dropped the center diffuser, used a hockey puck on the brace and lifted the rear, removed tires, removed filters. Had a stud on the header side on each side of the car come out with the nut, just screwed it back in when re-assemble. Test drove it, went up to 6k since I am still breaking it in. I have the valve controller and with the valves closed, no difference between stock and gutted. Valves open it is about .5 times louder, not 2 times louder more like 1.5 times. I didn't hear any drone. Didn't change the tone, just more volume which is as expected. It is far from being too loud, I was worried because I am not in the market for a screaming exhaust. Downshifts with auto blip are so much better now. I am keeping this car for a very long time so I dont care about returning to stock so if that is the case I would recommend this mod, it was worth the time and effort. Had the car a week, wish I have done it sooner and was pissed that I had to do this mod because it should sound like this from Porsche. Sad days.
Avera (11-04-2022)
TechnicianNick (01-13-2023)
#264
Would love to see some more dyno work done with this mod. Such as:
-Stock OPF, versus gutted OPF, versus Akra (or similar) OPF
-Then, same as above, but with a Cobb or similar tuner.
Would certainly take some work, but would be priceless info!
#265
Another thought about the dyno previously done:
- Could tying open the PSE permanently be causing a loss in torque in the low to mid-range? I know it is normally closed at lower RPM, hence the reason people tie them open to gain more sound, and maybe it is done to improve backpressure/torque? Just a thought...
#266
#267
Thought I’d bump this thread.
Traded-in my Spyder for my inbound RS.
Left the Soul OAPs on; so have a stock pair of OEM OAPs laying around.
If anyone interested PM me and we can work something out.
Came off the car after 2 months 1000 miles.
#268
