718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Oil Consumption Discussion
Old 07-06-2021, 12:12 PM
  #166
Westcoast
Westcoast's Avatar
Received 4,739 Likes on 2,756 Posts
Originally Posted by frosty911
I just did my oil oil change myself.
I bought 8 liters of the 0w40 mobil 1 x3 c40 at the daeler for 13.95 each. In Canada so can$
I also bought the filter, gasket and oil plug. Just didn’t want to mess around.
13,95 can$ at the dealer
Hey Frosty how about updating the location in your profile so we know where you are at... still no sign of C40 Mobil 1 in Victoria BC (that I am aware of).
Old 07-06-2021, 10:18 PM
  #167
frosty911
frosty911's Avatar
I’m in Montreal. Bought the oil and filter, plug and gasket at Porsche rive sud. ( Porsche south shore) This was all in stock.
got in , got out in 5 minutes.
Plus if something was to happen to motor, less likely imo to have warranty problems if I bought my stuff straight at the dealership where I bought my car.
Filter was 32$, gasket for oil filter casing was 19$ and oil plug was 9$.
I don’t see why your local porsche dealer wouldn’t have the oil in stock.
The parts guy knew exactly that it was the x3 c40 that was required for the gt4 2020.
Old 07-07-2021, 01:38 PM
  #168
Westcoast
Westcoast's Avatar
I have no idea either, all I know is what they said... not in stock.
Old 07-08-2021, 03:47 PM
  #169
N11g
N11g's Avatar
The Ottawa dealership has had x3 c40 0W-40 since (at least) Feb of this year. I bought 10 quarts in April.
Old 07-29-2021, 07:22 PM
  #170
street
street's Avatar
Originally Posted by VVG
Two things:
1. Changing the oil after break in isn't going to help in any real way. It is more a theoretical idea to get rid of "break-in debris". It will not increase engine longevity by any meaningful amount. The caveat here is if you have seriously tracked your car for any amount of time, you should change the oil more frequently than every 10,000 miles or every year.
2. Following the recommended break-in in the manual is the worst thing can you can do in terms of oil consumption, as this is not the proper way to get the piston rings to properly seal. The break-in recommendation in the manual is put forth by the legal department, is completely unscientific, and is the same for every single Porsche engine, all the way from a turbo-4 to the highest revving NA motor. There is actually a very good, engineering based break-in recommend by Andreas Preuninger that is somewhere on this website, if you want to do a search. It basically involves increasing the allowable maximum revs every few hundred miles. Even within the rev limits, you should be driving at the top of the rev range.
Ever see the oil after break in? It can range from a little shiny to metal flake.
Old 07-29-2021, 08:01 PM
  #171
FASTRKMAN
FASTRKMAN's Avatar
Yes Mark has had it in stock since last June 2020. If you ever need they also do free fill ups
Old 09-13-2021, 05:20 PM
  #172
FLCAYMAN
FLCAYMAN's Avatar
Default Your 4.0 oil consumption experience.
I’ve gone through ~3/5 of a quart in the first 2100 miles. I find this perfectly acceptable especially during break-in. If anything it should improve. What have you seen? I know DI engines can vary greatly.
Old 09-13-2021, 05:33 PM
  #173
Tief Lernen
Tief Lernen's Avatar
There are several other threads on the same topic. It seems like these engines do burn oil even after break-in, but mostly from high-RPM, high-load operation.
My GT4 seems to burn about 0.2 quarts with each track day (i.e. just under two hours of track time). I don’t notice substantial consumption outside of track days and I don’t recall seeing much of a drop before I did a break-in change at 2,000 miles.
My previous 718 Boxster S - broken in exactly the same way, and tracked just as hard - burned no oil, ever, as far as I could tell. Sold with 24,000 miles on it.
Old 09-13-2021, 05:59 PM
  #174
Denny Swift
Denny Swift's Avatar
Received 1,627 Likes on 684 Posts
I have had my car almost exactly one year. It has 5,000 miles on it. I red line it often, and auto-crossed it once. I have not added any oil, and the level is still in the middle of the range. I’ll be getting my “free” oil change next week.
Also, I had a 981S for 8 years before my Spyder. I added one quart during the first year I had it, but I never had to add any oil between yearly changes for the following 7 years.
Old 09-13-2021, 09:57 PM
  #175
wistful
wistful's Avatar
BGTS 4.0. ~3000 miles.
i was extremely good for the first 2K miles. nothing over 4k.
the last 1000 has been..... spirited. i just hit my min oil and am trying to find some C40
Old 09-13-2021, 10:04 PM
  #176
FLCAYMAN
FLCAYMAN's Avatar
Sounds like our experience is very similar. My dealer told me to visit at any time for a top-off so check in with yours if nearby.
Old 09-19-2021, 06:06 PM
  #177
mm95510
mm95510's Avatar
Hi RZ spyder.
I have a 2021 Spyder with 3,000 miles. Just got a oil warning. I'm down a quarter of oil. Freaked me out until I starting reading some posts and is appears to be common with our cars and the GT4.
what are you hearing?
Old 09-19-2021, 06:34 PM
  #178
rzspyder
rzspyder's Avatar
Originally Posted by mm95510
Hi RZ spyder.
yeah don’t worry it’s expected to eat oil. The oil consumption also depends on how frequently you rev it to higher rpms. I’ve got around 7K miles and have refilled it 3 times now.
omar0022 (09-19-2021)
Old 09-19-2021, 07:44 PM
  #179
CaymanMatt
CaymanMatt's Avatar
Hi RZ spyder.
I'm somewhat surprised that so many owners don't check their oil long before they get to this point. I try to check it most every time I drive so I can see if it's dropping.
MOO & FWIW
Old 09-19-2021, 07:52 PM
  #180
phefner
phefner's Avatar
Originally Posted by omar0022
Just out of curiosity has anyone had any luck having the dealership do a top off with oil when you get the notification to add some? I know they give you the extra quart but as a courtesy, do Porsche dealerships do top offs for oil?
Umm, yes. My Porsche dealer happily tops fluids off if I make a drive by on a Friday or Saturday afternoon.
Even my BMW dealer does this.
omar0022 (09-20-2021)
Quick Reply: Oil Consumption Discussion
