718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Gear 1-2 grind
Old 10-24-2023, 08:50 PM
  #1081
MrFunk
MrFunk's Avatar
Originally Posted by UncleDude
Does this coincide with a shifter **** upgrade?
No.
I can't see how a shift **** would cause a gear grind either...
Old 10-24-2023, 09:08 PM
  #1082
UncleDude
UncleDude's Avatar
Received 5,452 Likes on 2,233 Posts
Originally Posted by MrFunk
No.
I think there is a user component to it, that’s why I asked.
Old 10-24-2023, 09:13 PM
  #1083
6IXSPD
6IXSPD's Avatar
Interestingly, mine has stopped grinding now. I haven't had this happen in ~2500 KM. Still worth doing a gearbox flush though just to clean out the shavings.
No.
It shouldn't. These cars use a shifter cable linkage setup, not a lever and selector rod setup. The weight of a shift **** isn't being transmitted to the internals of the gearbox.
Old 10-24-2023, 09:18 PM
  #1084
RoadrunnerGTS
RoadrunnerGTS's Avatar
Received 1,096 Likes on 548 Posts
As said before, I have been told by expert techs that it is syncros bedding-in. Typically happens in new'ish cars or those that aren't driven hard enough. Remedy is high RPM fast shifts between 1-2.
Old 10-24-2023, 11:38 PM
  #1085
AdamIsAdam
AdamIsAdam's Avatar
Received 4,040 Likes on 1,750 Posts
There is not, I promise you that.
Old 10-25-2023, 12:22 AM
  #1086
UncleDude
UncleDude's Avatar
I don’t really agree, but I’ve made my arguments 2x in the thread already LOL.
Old 10-25-2023, 01:10 AM
  #1087
AdamIsAdam
AdamIsAdam's Avatar
Yup, me too. I can say this without a doubt, that in my case, it's not driver error. It wasn't me causing the grind, and it's not me preventing it. The grind just went away at just over 700 miles.
Old 10-25-2023, 08:38 AM
  #1088
MrFunk
MrFunk's Avatar
I hear ya
And none of us have ridden with each other... so its a logical comment... you don't know how in driving or shifting... I get it.
I can say this... 30 years of MT experience. I've never owned an automatic... and I've not had this issue before... lots of older cars without synchro etc. Lots of brands. Short shift kits and weighted shift **** upgrades... you name it. Never wore a clutch out.
Is my driving getting sloppy in old age? Perhaps! Hahaha probably not though.
I will say I only notice it in leisurely city driving. When driving spirited in the country I don't notice it. And I've only just recently started driving the car a bit around the city... which I don't feel is fair to the car. It likes to stretch its legs.
Old 10-25-2023, 07:26 PM
  #1089
MrFunk
MrFunk's Avatar
I had a good spirited run in the Spyder today.
I could not reproduce the 1=>2 shift grind.
The car likes to be driven this way.
Old 06-19-2024, 08:54 PM
  #1090
H8 Rain
H8 Rain's Avatar
I've got a 2020 Spyder that I've had since the summer of 2020, currently at about 12,000 miles. This 1 2 shift "Grind" or "Scrapping Noise" (I'll call it an Event) has happened a couple of dozen times over the last few years, never really something I could re-produce at will but something I learned to live with by not accelerating hard from 1st and to make a point of doing a slow 1 - 2 shift.....mostly that worked but every so often the "Event" would pop up and any passenger I had with me at the time would say "What the heck was that? First time driving a manual is it?".
This year, after my first drive of the season, it happened again and I'd finally had enough
So prior to my most recent 4 year service I sent my dealer the attached service bulletin and said "Add that weight during my next visit". They ordered the parts (that I had to pay for because Porsche doesn't agree that this horrible noise is a "fault") and installed (also my at my cost) them when they were doing my yearly service.
So far....the 1 2 "Event" hasn't repeated and the sporty shifts that the bulletin says might be impacted by the add of this weight, feel the same to me
If you, like me, suffered through this and have/are waited/waiting for it to go away and hasn't, maybe this fix is worth a try because for me, its so far so good.
silverscooby27 (06-19-2024)
Old 06-19-2024, 08:59 PM
  #1091
Bob Z.
Bob Z.'s Avatar
Received 3,455 Likes on 2,359 Posts
What did it wind up costing you?
Old 06-19-2024, 09:01 PM
  #1092
H8 Rain
H8 Rain's Avatar
Approx $750 CAD....parts and labor
Old 06-19-2024, 09:02 PM
  #1093
incursion
incursion's Avatar
Muy interesante! Thanks for the post.
Old 06-20-2024, 09:57 AM
  #1094
AdamIsAdam
AdamIsAdam's Avatar
What's crazy about all this, is that some Cayman 4.0's were doing it. And as I recall, Porsche's "fix" was to make the GT cars feel like non-GT cars with this fix. So go figure.
Old 06-20-2024, 11:32 AM
  #1095
smilin
smilin's Avatar
maybe this fix is worth a try because for me, it’s so far so good.
great info. thank you!
Quick Reply: Gear 1-2 grind
