Multifunction default language
Just entered Porsche community with purchase of 2017 718 base model. Got it from a third tier dealer( you know the ones in a strip mall selling cars they get at auction, but can't support), but please dont judge... this was a financial stretch...
Anyways... having an issue where the multifunction display language reverts back to French everytime i start the car.
I change it to English, and its fine for that driving session, but after i turn off ignition and restart the car, its back to French again. The PCM does not have this issue. It has its own language setting and remembers the chosen settings.
i have not yet purchased a scan/diagnostic tool, but plan to. Is this something that could be corrected via one of the more reasonably priced units, or will i need to take to dealer with the 'big boy' tools.
Any guidance is greatly appreciated. Thanks in advance.
do you have memory settings on the driver's door for the 2 seating positions? sounds like the key is programmed to use french as the default language. if so you will have to set things the way you want and then re-program the key using the buttons on the door.
L'électronique Porsche c'est de la merde
ldamelio (05-12-2023)
Thanks to all for responses... got it fixed
Yup, as Nineball and Pointbye suggested the key memory was the secret.... thanks for quick response
Merci Idamello... J'ai commencé mes études de français aujourdhui, et j'espère un jour rétablir intentionnellement les paramètres en français...LOL
