718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Soundaktor Another Way
Old 10-09-2018, 09:58 PM
Wine.o
Wine.o's Avatar
Default Soundaktor Another Way
Well it seems the 2019's do still have the soundaktor, but the control module has clearly been moved as there's nothing under the liner btwn my left rear wheel and the left tail light. While not *quite* as simple as unplugging the controller, disconnecting the soundaktor itself was still super easy. Took just a few minutes with no real problems. Pics below show what I did... (One note, speaker covers pop free from the INSIDE edge)
Old 10-10-2018, 10:30 AM
rdmustang
rdmustang's Avatar
Are you sure that's not just part of the sound system? In my car I hear music coming from behind my head when playing music.
Old 10-10-2018, 11:58 AM
Wine.o
Wine.o's Avatar
No, the speakers behind the seats (seen in the first few pictures are not disconnected. You just need to remove their covers to move the cabin liner out of the way.
Old 01-13-2019, 01:36 PM
Norsk
Norsk's Avatar
Wine.o thanks for this post, it was very helpful. My wife just got delivery of her ‘19 Boxster S. We did not order sport chrono or sport exhaust (it is PDK) however is is equipped with PSE. Why, I don’t know, must be standard equipment on new models. Also didn’t care for the manufactured sound, so I followed your directions to get at the soundaktor. On this model there are two different plugs and sets of wires going to it, instead of the one set in your pics. I unplugged the brown/green red/green set and left the yellow/red with the intension of unplugging that as well if the sound was still obnoxious, but just the one plug seems to have done the trick. Now it is quiet in normal mode, but with sport mode / PSE on, the extra exhaust note is outside where it belongs.
Old 01-13-2019, 01:53 PM
Todd B
Todd B's Avatar
Yet another way. You can also remove the 7.5 amp fuse (fuse 10) on the fuse panel in the trunk on the passenger side. This circuit is only for the soundaktor. Pulled the fuse before I left the dealer.
anthonyf202 (10-12-2020)
Old 11-28-2019, 05:21 PM
Reiver
Reiver's Avatar
Old thread I know.....is the same fuse the soundaktor power on the 2018's? I'd like to turn that off and see the dif? I should ask if this exists in all levels of Caymans with sport exhaust?
Old 11-28-2019, 07:57 PM
InTgr8r
InTgr8r's Avatar
Yes, the fuse is in the interior rear quarter panel behind the trim.
One of the first things I did with mine. (CS 2018)
Old 11-29-2019, 12:45 AM
Todd B
Todd B's Avatar
Yes, mine is a MY18 GTS
Old 11-29-2019, 01:05 PM
Reiver
Reiver's Avatar
Thanks...where, what panel, are you referring to that has that fuse behind it...?
Old 11-29-2019, 02:50 PM
BlueNorther
BlueNorther's Avatar
Right rear side of rear trunk, just pull away the carpet. There is only one 7.5 amp red fuse, top row, right rear as you look at the box, next to the two yellow 5 amp fuses.
I just pulled mine, I didn't feel the disconnect was necessary during the top down season, but now it's beginning to get to me...
The following 2 users liked this post by BlueNorther:
anthonyf202 (10-12-2020), Graufuchs (10-17-2020)
Old 11-29-2019, 05:02 PM
matmanx1
matmanx1's Avatar
I pulled the fuse in my 2018 Cayman within 1 day of me getting the car. I really like how it sounds "au naturale". No fake noises needed.
Old 11-29-2019, 05:25 PM
Reiver
Reiver's Avatar
Thanks Gents...appreciate the assist for a new owner.
Old 10-12-2020, 12:41 PM
718GTS
718GTS's Avatar
I finally did take the fuse out last weekend. I really enjoy the sound in the cabin now. No more low frequency drone in Sport Mode. I realize it's a personal thing but it's so easy to remove the fuse that one should consider it and worst case put it back in.
The following 2 users liked this post by 718GTS:
Old 10-12-2020, 05:34 PM
Ray831
Ray831's Avatar
I see you seem to have a GTS.....I thought that the 2018 GTS did not use the sound thing.......I will go look at mine.
Old 10-12-2020, 06:39 PM
718GTS
718GTS's Avatar
it does have it. The 7.5A fuse is there, next to the two 5A fuses, in slot #10 in the trunk right hand side.
Ray831 (10-13-2020)
Quick Reply: Soundaktor Another Way
