:: ECS Tuning :: Quick Cures For Common Cayenne Concerns
Former Vendor
Chasing a mystery coolant leak? If your 2003-2006 Cayenne is losing coolant, odds are you can trace it to the original plastic coolant pipes located beneath the intake manifold. That's why ECS Tuning has assembled the most comprehensive coolant pipe repair kit available in the aftermarket. Our problem solver package includes original equipment cast aluminum coolant pipes, hardware, and seals. We even include a new thermostat gasket, a part commonly excluded from competitors' kits.
For information and to purchase Click here
Your hatch shouldn't be falling on your head while you unload your cargo. This kit includes everything you need to replace your hatch struts.
For more information and to purchase Click Here
The High and Low Pitch Horns commonly go out on Cayennes. Replace them with direct fit quality Genuine Porsche components.
Replace your standard Base/S/Turbo lower control arms with units from the Turbo S. With thicker, heavier duty bushings, you won't have to deal with torn or loose bushings again, and you will have a more responsive and predictable ride.
Hatch window won't open? A likely cause is a faulty tip switch. This updated switch includes a new wiper arm cap, since yours was probably missing anyway.
If you're hearing thumping noises or feeling excessive vibration, you should make sure to check your center drive shaft support bearing for wear and failure.
This component is a simple replacement and will rejuvenate your vehicle’s performance and fuel efficiency. If you are replacing any piece of your ignition system, it's best to replace all serviceable components at once, so don't forget spark plugs!
Take a look at your other mounts prior to ordering. Grab your engine by the top and shake it. If it moves significantly, replace all of the mounts to stiffen up your entire driveline for better performance.
If you have ever got the message telling you to replace your cornering headlights this is the solution you need to get that error message off of your screen.
Improve your interior lighting experience, and open your door to a world of stunning light from Ziza.
Former Vendor
If you are upgrading the brakes on your Cayenne with a big brake kit or are just interested in an improved feel in your stock pedal, ECS Tuning has your solution. These premium brake hoses are stronger, more durable, and better protected than the originals. They are shielded in stainless steel mesh reinforcement, and coated with bright red vinyl for added protection. ECS Tuning's Exact-Fit Stainless Steel brake lines will provide better braking feel and improve your safety on the road.
For more information and to purchase at the new Holiday price Click Here
The ad say's not for vehicles with E81 performance package which would mean not for a Turbo S either as the two are the same, just without the badges. Do you have lines for a '06 Turbo S?
All Cayenne brake hoses are the same so the info is incorrect, they will fit Turbo S and E81 cars. The difference on these cars is the solid line to these hoses, not the hoses.
Former Vendor
Sorry for the confusion and thank you for catching that It will fit the 2006 Turbo S, the only thing it won't fit is the 2008 Turbo and 2009 and up Cayenne's with PCCB's.
Oh damn. I replaced my hatch shocks with WINDOW GLASS SHOCKS.
**** me.
**** me.
My pipes let go in my Turbo S yesterday. It looks like the coolant pipe kits and coolant are backordered. If the coolant is not available, can I get the rest of the kit minus the cost of the coolant? I'll just source the coolant somewhere else. I'd like to have the parts here so that I can begin working on it this weekend.
