997 Turbo Forum 2005-2012
The Blackstone Labs Oil Report Thread
Old 10-24-2013, 05:41 PM
  #61
Kevin
Kevin's Avatar
Denis the Valvoline looks good.. I'd run it in a second.. Send me a case!! I'd run Mobil RACE 0W50 if it was in a 5W50 (the only thing that worries me is the detergent package>different subject)
From what I have seen, the 0W40 sheers to a level lower than what this engine needs. Please realize that in the 959, GT1 spec and water-cooled 962's they ran 15W50 >and even higher. The 5W40 and 5W50 are more temperature stable and sheer less.
Old 04-23-2014, 12:39 PM
  #62
saabin
saabin's Avatar
Here's my report from my oil change I did this past weekend.
Nothing jumps out to me as abnormal..
I went with 5W40 TDT oil after my report & oil change.
Old 04-01-2015, 06:45 PM
  #63
saabin
saabin's Avatar
Here's my report from this year..
Now my copper is in line with samples I have seen from other turbos.. it was fairly low during my first sample.
Old 04-01-2015, 06:46 PM
  #64
jem7v
jem7v's Avatar
Without reading through this entire thread. What exactly is the best oil for our cars?
Old 04-01-2015, 06:53 PM
  #65
LexVan
LexVan's Avatar
Received 5,388 Likes on 2,509 Posts
At least spend 20 minutes and read all of Kevin's posts in this thread.
Sent from my iPhone using Rennlist
mavfan909 (10-27-2022)
Old 04-01-2015, 09:24 PM
  #66
TT Surgeon
TT Surgeon's Avatar
Always stick with the factory recommended fill outlined in your manual.
Old 04-01-2015, 11:23 PM
  #67
Boeing 717
Registered User
Boeing 717's Avatar
Motul is the shiznit.
Old 04-01-2015, 11:33 PM
  #68
strato58
strato58's Avatar
I thought Mobil 1 TDT was the Shiznit? I can't keep up with you guys...
Old 04-01-2015, 11:50 PM
  #69
Boeing 717
Registered User
Boeing 717's Avatar
Used to be the Shiznit, Motul is the current Shiznit.
Old 08-08-2015, 04:44 PM
  #70
LUXEMBOURGER
LUXEMBOURGER's Avatar
Originally Posted by Kevin
Denis the EURO 5W50 Valvoline is not available in the US.
It's easy to say right now that 1000 PPM is suffice, when just 8 years ago we had 1600PPM and prior to 2000, we had 2000PPM.. These engines were designed for the higher levels.
Great Kevin,
For those of us based in Europe.. which oil would you recommend for a 997.1TT?
Old 08-08-2015, 05:11 PM
  #71
Kevin
Kevin's Avatar
Do you test your used oil? You have to dig deeper and research the oil specs. What is the VI, HTHS, and metal conditioning additive package. The Euro Mobil 5W50 is the starting point to compare "other" oils too..
Old 02-03-2016, 07:03 PM
  #72
saabin
saabin's Avatar
Here's my latest report.. I ran M1 5W40TDT most of the year..I'm sure the dealer put M1 0W40 back in as make-up oil when they had the camshaft out for repair.
Old 03-10-2016, 09:31 PM
  #73
strato58
strato58's Avatar
Reviving this thread as im getting ready for my "winters over" oil change. Im thinking of Motul V300 this time. Was using M1 TDT 5w40. Not sure if im making a positive move and the cost is more. Any new thoughts on this topic?
Old 03-10-2016, 09:36 PM
  #74
LexVan
LexVan's Avatar
Use Mobil 5W50. On sale at Napa for $5.99. Then take another $12 off with the Mobil rebate. Limit 2 cases. Done.
Old 03-26-2016, 10:45 AM
  #75
ctony66
ctony66's Avatar
I was wondering if anyone could give some insite on my sample. It came back with high nickel and other metals again. I know it's probably not good but I was just wondering how bad it really is if at all. Has anyone experienced numbers like this.
Quick Reply: The Blackstone Labs Oil Report Thread
