Oil temp gauge (or correlation to water temp)
Does anyone here run an inconspicuous oil temp gauge? If so, show me?
Either that, or is there a decent correlation between water temp and oil temp? I have a habit of not "getting on it" til the water temp is pretty much up to 180 but I wonder how that correlates with oil temp in these cars. In my BMWs, water temp leads oil temp by 40-60 deg. F.
The oil temp lags behind the water temp on engine warm up. After my water temp gets to 180 I normally drive about 5 more miles at 3000 RPMs and then assume my oil is up to temp and I can get on it. This is only a guess however. Maybe someone has an oil temp gauge and can confirm this.
Oil temp takes a lot longer to get up to temp than water temp.
I'm not sure why Porsche did not include an oil temp gauge with our cars (I'd take that any day over the voltage gauge!), but it would be quite useful.
I'd be interested to hear from 997 (I think they have an oil temp gauge or was it the 7gt3?) how long they need to drive before they see oil temp come up to temp.
On my E30M3, I could drive for 20mins before the oil gauge would even move. So this wasn't even up to "operating temp" for the oil. That's why they say you need nice long drives to get the oil up to the proper temp to "boil" out any moisture in it.
I have an 07 S Coupe 997 3.8 engine. The 997's have both gauges. My water temperature reaches 175 and the oil temperature has yet to move. It normally takes about three miles of under 3000 rpm driving to get the water temperature to 175 and then about another two miles before the oil temperature to settle in just under 200 on my gauge. When I drive hard the gauge does go just above 200. I am sure the water temperature gauges on the cars are not accurate as mine never gets above 175. I think Porsche makes it that way so we don't worry. At any rate, from my observations, there is quite a time difference from hot water to hot oil. I would not get on it too hard for a bit after reaching optimum water temperature.
Captain Obvious
Super User
Super User
Unless under racing conditions, why would one care about the oil temp? Porsche didn't put it in the clusture because there is no reason the driver needs to know.
Captain Obvious
Super User
Super User
DEs are racing conditions so I can see some reason for it but what will be your threshold value for oil temperature? What can you get out of it that a coolant temperature sensor can't show. If the coolant gauge looks normal, so should the engine.
To note, with my 3rd radiator, 160o thermostat, and fan hack my coolant temperatures rarely notch above the '8' on the temperature side...while I watch my oil pressures continually drop (in bad traffic or on a long DE day) to a few shades over 1 bar. Simply a symptom of the oil getting hot, thinning out, and dropping pressure.
So, to know exactly how thin my oil is getting, I'd love to have an oil temperature gauge, rather than "guesstimating it" via pressure.
I am with you.. we need to find a mod to read oil temp !
Only thing I see available would be the location of the oil pressure sensor.
Either replacing it with oil temp instead OR add a T and plug both at that location. unfortunately don't think anybody has ever done it on rennlist
I have not seen any oil cooler mod either. Many 996 spec racer seems to say the hardware on the car is fine even for racing and many have raced for a few years without mod. I am worry as well when I see my oil temp drop on DE
IIRC that oil galley is a dead end.
If so there is no oil flow thus the temp reading will not reflect the oil temp say at where the oil is fed to the mains.
