Warning, Oil Thread! Miles and Time intervals?
What intervals are you doing between oil changes for street driving?
I just did circa 1 year 3000 miles with Mobil 1 V-twin 20w-50 and it's soo clean I don't see why I don't go beyond 1 year. There is high silica possibly because my air filter hasn't changed in at least 6000 miles.
As a base line to learn my car I figure I should go for longer intervals now I think. No?
Thanks guys. I thought about posting in the 993 forum but with the turbos maybe it's different. Sorry for the size/format.
ps - got the golden rod and it's so much more NORMAL.
I'm no expert so I spoke to Mobil oil engineers on 2 separate occasions. They are easy to reach for phone chats. I use M1 V Twin and drive between 1,000 and 1,600 miles a year, most of it highway speed, no tracking. Advice was that oil would last much longer and to do it every 2 years/4,000 miles at most. Also said oils take 1,500 miles to break-in so actually better to leave it in. I've also spoken to a couple collectors of gazzilion dollar Ferraris that do under 500 miles a year and they do it every "couple" of years. My tech also says every 2 years so that's what I do. As for your oil analysis, I have no idea but am interested in knowledgeable comments.....
Received 5,414 Likes
Change every year. Change every 5,000 miles. WECF.
What air filter are you running? Your silicone is high.
Sent from my iPhone using Rennlist
If an employee at any manufacturing company, tells you not to spend money annually, then that would seem credible to the quality of their product and knowledge of it. The common denominator nowadays is to lie through your teeth to make the sale/profits. Chaulk one up for M1!
Your viscosities are both WAY OFF for Mobil V-Twin 20W50. So is your zinc and phosphorus.
What oil did you run in 2013? I don't think it was Mobil V-Twin, was it? It was something else. Right?
That oil from 2013 is still "washing" through your system. It's bringing your SUS 210 viscosity down. It should be much closer to 100.
Your cSt 100 is also way low. This should be 20 or higher all-day-long.
You should also be seeing zinc in the levels of 1,500 PPM and phosphorus in the 1,350 range.
I would expect your next UOA to improve. Only your Alum. level looks good at 3. Your iron at 12 is high. With a healthy engine, this level will get closer to 7 using V-Twin. Same with your copper. You are very high at 18. Look for this number to start dropping into the 4 range.
Lastly, using OE Porsche engine air filters, your silicone should be closer to 3. You must be running some aftermarket air filter (maybe K&W) or have a air leak someplace.
Oh, in the future, don't pay Blackstone extra money to test your TBN. It's unnecessary. If you change your oil yearly, AND every 5,000 miles, those numbers will always be fine with V-Twin. You're not trying to extend your oil change interval, you're trying to extend your air cooled motor's life. Now, do the right thing!
Your viscosities are both WAY OFF for Mobil V-Twin 20W50. So is your zinc and phosphorus. What oil did you run in 2013? I don't think it was Mobil V-Twin, was it? It was something else. Right? That oil from 2013 is still "washing" through your system. It's bringing your SUS 210 viscosity down. It should be much closer to 100. Your cSt 100 is also way low. This should be 20 or higher all-day-long. You should also be seeing zinc in the levels of 1,500 PPM and phosphorus in the 1,350 range. I would expect your next UOA to improve. Only your Alum. level looks good at 3. Your iron at 12 is high. With a healthy engine, this level will get closer to 7 using V-Twin. Same with your copper. You are very high at 18. Look for this number to start dropping into the 4 range. Lastly, using OE Porsche engine air filters, your silicone should be closer to 3. You must be running some aftermarket air filter (maybe K&W) or have a air leak someplace.
I'd rather change the oil filter than the air filter.
It's probably me... but getting that airbox cover is one of the most stressful items to perform. Mostly b/c it's supposed to be so easy... and it just isn't It's horrible. I'd rather jack the car up, take the wheel off, pull the wheel well out (to get to big filter), change both filters, and change the oil rather than fit the airbox cover back on correctly.
Airbox cover fit: work 5 min, step back shout expletives for 1 min, walk around scratching head 1 min, repeat this process 10x=70min
Oil change: work nice and methodical 15min, sip of suds 1 min, repeat 5x=65 min and a lot more fun
PiB993, I'm still curious about the oil that was in the car at the 10/23/13 change. Do you remember what it was, brand and viscosity?
So this means you must be trying to get the airbox cover off W/O removing intercooler? Can't see what else would make it so hard for you. I'll take tackling the airbox over getting to #6 plug any day.
