Project Lightweight C2
#46
Just bringing the seat fixing issue back.
On the 964, there is a seat belt mounting point for the buckle. If you are using a full harness and the mounting points are body mounted, then I see no issue at all from removing these 2 bolts. If, however, the standard seatbelts are used, I would not compromise and reinstate those bolts.
Over the last 20 years I have been involved in many seatbelt and other passenger and equipment dynamic tests and it never seases t o amaze me that something tried and tested can so easily fail when the parameters are changed only slightly.
Now about the wheel nuts do you think I could get away using 4 of the 5 nuts on each wheel or the steering wheel centre nut
#47
some more bits removed
0.142kg drivers footwell battery cable shroud
0.449kg sunroof motor cover panels
0.768kg central tunnel carpet (not completely removed)
3.229kg central tunnel sound deadening (not completely removed)
0.156kg pair of rear seat locking pins
1.548kg drivers seat electric motors, cables and steel cross member
0.044kg leather swatch sample under the drivers seat
1.500kg drivers floor pan sound deadening
0.087kg B-pillar vinyl trim
0.935kg radio chassis and some wiring
Weight removed running total 187.5lbs/85.077kg
Nearly 16yrs since I had my own car project and I'm enjoying every minute of it
Still yet to create a photo sharing account to show pictures of my build progress to date
In the meantime hope you'll find one of my previous car projects a little more interesting than reading a list of weights for 964 parts
915kg of Le Mans GT1 goodness
#48
not updatd this for a while, removed some more parts and broke through the 100kg barrier
0.318kg bitumen sound deadening strip on central tunnel LHS
0.108kg spare wheel clamp and bolt
0.113kg ABS pump plastic cover
1.682kg alumnium jack
0.471kg kack handle
0.601kg wheel brace
13.487kg spare wheel
1.973kg tool roll
0.135kg steel battery cable shroud under the spare wheel
0.770kg sunroof motor and mounting bracket
0.273kg bitumen sound deadening strip on central tunnel RHS
0.681kg bitumen sound deadening on rear floor behind front seats, pair
1.976kg sound deadening under dash and front wheel arch area (still some left behind the pedals)
0.708kg plywood pedal board
1.2kg tyre pump kit
1.169kg pair of door pocket lids
1.875kg pair of door pockets
0.423kg pair of door speaker wiring mystery junction boxes
Weight removed running total 113.05kg or in old money 249.2lbs
if anyone can help I'm still looking for accurate weights for the following
front underfloor, part covering the front subframe
aircon delete
secondary muffler delete
0.471kg kack handle
0.601kg wheel brace
1.973kg tool roll
1.2kg tyre pump kit
aircon delete
#51
still cleaning glue off, one more session and I should be done, just a hateful but necessary job
took off a few more easy to remove parts, still got loads to go
0.042kg Porsche bonnet badge
0.916kg glove box lid
0.976kg steel ECU tray inder passenger seat
0.049kg plastic bracket under brake fluid reservoir (really not sure why this is fitted)
0.355kg more stereo wiring
0.044kg brake and clutch pedal rubber pads
0.445kg HVAC unitl plastic shroud and bonnet rubber seal
Weight removed running total 115.87kg or in old money 255.4lbs
One area I will really concentrate on is removing wiring for stuff I don't need eg, brake pad wear, interior lights, reversing lights, under bonnet light, seats, wing mirrors etc
Copper density is 14% heavier than steel so I'm sure I'll find plenty of weight once I start stripping out looms for the rear wiper, door mirrors, central locking, reversing light, brake pad wear etc
Also found this, copper coated alumnium battery cable, 1/2 the weight of normal battery cable and uses crimped on connectors
http://www.jegs.com/...266308/10002/-1
#52
Hi Captain Ahab,
I removed all unnecessary cable - incl. all Stereo/Radio, etc. I came up to 3,8xx KG in total. It was fairly easy once I started...
so - in fact easy kilos. My car is pretty stripped and Carbon substituted ;-) and it is down to 1150KG - I guess with some Literes Gas.
Thanks a lot, greetz Tim
#54
Tm and Rob, thanks for your comments, 1150kgs is a sizeable saving
3.8kgs for the wiring is more than I had estimated which is good news as its starting to get a little harder now but I still have plenty left to remove
#55
Attacked the alarm and immobiliser wiring today, started off cautiously, systematically checking the engine would restart after each snip and then I got stuck in and ripped the whole lot out chucking it in a heap as I found more and yet more if it.
Bigger pile of wires than I had originally thought there would be
Car had an alarm and an immobiliser fitted, think the alarm was an old one that didn't work.
The immobiliser worked as now the car won't start but once I reconnect the ignition wires it was spliced into everything should be fine, fingers crossed
Today's list of stuff removed,
2.791kg alarm boxes, immobiliser, wiring and sensors
4.024kg pair of interior door panels and door interior handles
1.159kg pair of interior door tops
0.351kg pair of bonnet gas struts
0.093kg under dash HVAC duct, rhs above drivers feet
Weight removed running total 124.29kg or in old money 274lbs
#57
Not done anything special, just removed parts I think I have no need for, at this stage would prefer to go too far than not far enough.
The radical stuff will come along later in the build
#58
From various suppliers websites, a straight through cup bypass exhaust pipe is a 25lbs saving over the primary muffler so I'll add it to my list
Not changed by me but by a previous owner
10kg cup bypass exhaust pipe (rounded down)
Weight removed running total 134.29kg or in old money 301lbs
#59
Very interesting, so what is your car weighting at the moment ?
It's always the small amounts that ads up and make a big difference at the end....
Best weight saving for me was going from Speedlines to OZ Allegeritas, improving weight ratio & handling ( 4kg per corners, spinning)
A 16 A Lithium batterie at 1 kg is also quite radical and very economical .....
#60
Mclaren F1 GTR on Vimeo
