rear spoiler update with questions
#64
Hi Guys,
Please someone can explain me what I did wrong, I have a 1990 C2 the spoiler module is under the passenger seat, and I swap the 39K resistor with a 24K resistor and the spoiler now open at 22 miles, actually the opposite of what I want.
[IMG][/IMG]
[IMG]<a href="http://s178.photobucket.com/user/k9doog/media/IMG_6421_zpsd6ee5c47.jpg.html" target="_blank"><img src="http://i178.photobucket.com/albums/w279/k9doog/IMG_6421_zpsd6ee5c47.jpg" border="0" alt=" photo IMG_6421_zpsd6ee5c47.jpg"/></a>[/IMG]
[IMG]<a href="http://s178.photobucket.com/user/k9doog/media/IMG_6420_zpsd071e20a.jpg.html" target="_blank"><img src="http://i178.photobucket.com/albums/w279/k9doog/IMG_6420_zpsd071e20a.jpg" border="0" alt=" photo IMG_6420_zpsd071e20a.jpg"/></a>[/IMG]
[IMG][/IMG]
#68
That's what I thought at first, so I went back to the place who sell me the resistor and ask them to recheck and they told it was the right one, I am not an expert in the subject, so probably you are right. Thanks
#71
"I measure the resistor and it shows 23.76 K ohm?"
The resistor is a 2% resistor (the right red band), so the value
is read from the left as; 2, 4, 0, and 2 zeros (multiplier - 100) followed
by the 2 percent tolerance. That resistor because it's a 2% has three
significant digits versus two for a 5/10% resistor plus the multiplier.
So the resistor has the correct value. It's actually within 1% of its value.
#73
If I recall correctly if you remove the 39K resistor, the spoiler extends around 20mph.
It would seem you might have a bad solder joint or a solder bridge. Look at you circuit carefully, and check your connections with your meter.
