928 Forum 1978-1995
Sponsored by: 928 Specialists
My Penance (Letting the cat out of the bag)
Old 12-20-2011, 09:22 AM
  #46
BPG_Austin
BPG_Austin's Avatar
I'd clean them up and leave them alone. They are very presentable and, more importantly, original. The next owner can make that decision. Just my .02.
Old 12-20-2011, 12:20 PM
  #47
928mac
928mac's Avatar
I don't know if I believe they were silver.
If they were dose that mean that my engine was silver as well?
Here is the color mine was before I repainted it.
It was a cream color al the way through.
Old 12-20-2011, 02:16 PM
  #48
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
My vote would be to leave them as is, they're looking good and have a bit of patina appropriate for a 24.5 year old car. Only original once.
Old 12-20-2011, 02:17 PM
  #49
heinrich
928 Collector
heinrich's Avatar
I agree
Old 12-20-2011, 02:46 PM
  #50
BC
BC's Avatar
There is no reason to not get new rubber - the idea was about the visual painted surfaces. As well as "what constitutes original and un-restored" and what that means for people.
The consensus seems to be, other than Ken, etc, to leave it.
I think I will do just that unless something else drastic is found. Obviously with new rubber and wires, belts, seals, and some work to make the bolts look shiny and cadmium plated.
Old 12-20-2011, 04:54 PM
  #51
928mac
928mac's Avatar
You could leave them, for now, and show the pics to some painters to see if they can match the color. then have them repainted later. I was not trying to say if I thought you should paint them. I was just commenting on what I thought the color was.
How ever you decide I am sure it will be way cool man.
Brad
Old 12-20-2011, 11:56 PM
  #52
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,255 Likes on 1,248 Posts
when you refit the cam covers make sure to put a bead of Hondabond 4 into the seal groove then fit the gasket this will stop it from leaking later,
replace the O rings on the elbows and plugs,
Hondabond can be used here as well if the bores are not smooth
Old 12-21-2011, 01:05 AM
  #53
BC
BC's Avatar
Don't like hondabond. Used it before and its like cement when someone else goes in. There are several more professional and great-sealing options.
Old 12-21-2011, 09:04 AM
  #54
Mrmerlin
Team Owner
Mrmerlin's Avatar
FWIW to remove Hondabond use either a rag or Q tip with acetone, it will neatly remove it, wear gloves.
Hondabond 4 is what I was specifying, its a semipermeable sealing compound, similar to Hylomar and Permatex, but easy to procure at the Honda dealer about 12.00 a 5 oz tube
Old 12-21-2011, 11:19 AM
  #55
SteveG
SteveG's Avatar
Did you say you were going to sell it? Then leave the covers, but otherwise, I say coat them. Mine were not in this great shape, but I don't think they will stay that way and I regretted not doing it while they were off.
Old 01-07-2012, 12:49 PM
  #56
BC
BC's Avatar
The spare is aluminum. Is that good or bad? Or normal? I don't ever remember seeing them aluminum.
Old 04-05-2012, 02:28 PM
  #57
BC
BC's Avatar
Some new pictures of the low-mile engine - some show interesting info.
The crank case looks basically new:
Valves and most of the ports are also quite clean - no slag or coke on the valves really:
Old 04-05-2012, 02:29 PM
  #58
BC
BC's Avatar
On the issue of the covers, I read the other threads and found the best match for the original color by the company that I can't think of the name right now.
I want to make them look like when it was new.
Old 04-05-2012, 03:44 PM
  #59
dcrasta
dcrasta's Avatar
You teasing us by showing some cleavage ??
Seriously, that looks like a cherry motor. I cant wait to see the rest of it. A S3 5 speed is my dream car!
Old 04-05-2012, 05:10 PM
  #60
outbackgeorgia
outbackgeorgia's Avatar
My 87S4 spare is aluminum
Dave
Quick Reply: My Penance (Letting the cat out of the bag)
