Total repaint (questions)
I will repaint my 1986 930 in Blood Orange. It's Meteor Metalic now (not original paint).
I know that many of you think that I should't do this but I can't just sell my car and buy another with the right color for me. Because there is no any 930s in sale at all in my country and custom duty for importing 930 from abroad is rather high.
I'm not going to sell this car in the future.
So please treat with understanding
I want total repaint (outside and inside car) to make my 930 look like it was born in Blood Orange. I want to repaint all the necessary parts and places of the car in Blood Orange.
Could you please help me with the list of the parts inside the car that should be repaint?
Any advices are also very welcome.
Thanks in advance!
Thanks in advance!
Caveat: am not a body/paint subject matter expert.
To paint your car correctly, obviously all glass, panels, and trim need to be removed. Not aware the factory ever painted the interior floor pans of production cars, but the pans undoubtedly have overspray from painting the door cavity [entry sill, hinge plate, striker plate]. Believe same goes for the exterior floor pans, front trunk, and engine compartment...never painted, but have color overspray.
If you want the gospel, reach out to John Paterek, PCA technical guru for all things body, paint, interior, and upholstery. Best of luck.
... <snip> ... Not aware the factory ever painted the interior floor pans of production cars, but the pans undoubtedly have overspray from painting the door cavity [entry sill, hinge plate, striker plate]. Believe same goes for the exterior floor pans, front trunk, and engine compartment...never painted, but have color overspray. ...<snip>
But I thought maybe I could ask a question here....
My 1991 964 Turbo has both the interior of the front trunk & interior engine bay sprayed by the factory. Out of curiosity, when did they start doing that?
Thanks,
=Steve
Having trouble visualizing past my gas tank, spare, and battery at the moment, but the front trunk is probably about the same, as the shock towers have a coat of color, as well. Trying to remember what the floor under the battery looked like the last time I was in there...
Received 5,414 Likes
Great color choice:
Sergey, after a little back and forth with Steve, the factory probably did paint the floor pans, trunk, and engine compartment...but not much more than a single rough coat. From what I remember, the color on my interior pans is pretty thin. John Paterek could probably quote factory procedures.
The engine compartment has full paint, the trunk has partial with more of an overspray on the lower areas, and the interior has more of a heavier overspray, and is then blacked-out along the outer edges and moves to more of a heavier black overspray as it moves further inward... if this makes sense.
However, if this car as been painted before in a non-original color, then its not going to hurt, and you may want to paint full paint the trunk area simply to obtain nicer more complete finish.
You are changing the color so do it like you want it as long as it is nice it will be appreciated by you as well as others.
If I were painting your car I would remove all the interior all the glass remove engine,pull back wiring harness front and rear,remove doors door panels,rear deck lid,trunk,gas door front &rear bumpers all glass for starters.I also recommend using basf 90 line if you want to go waterborne followed by glassuritt clear 923-200 or 923-210. I could go on &on about body&paint,but I think u get the idea.
