Fixing Flats
Fixing Flats
Oh man, I just picked up a large metal staple on my rear tires (Yoko AVS-Sports) ;-( Problem is its very near the edge of the tire. I have heard that its a problem in this area and the tire rep may recommend junking the tire.
Anyone know the "rules" or recommendations out there? I will not get it plugged but have the tire patched from the inside. I know its a violation of the Z rating of these tires but they are used in the city almost 100%.
Cheers,
Mike
Cheers,
Mike
If you are only talking about 80 mph and interstate type cornering, then I'd patch it and use it. If you are going to "drive" the car, get a good tire!
Well, it turns out that I the $#(*)$ wire staple was too close to the sidewall and the tire was toast. This was from my local tire guy down the street. **Sigh**. A 255/40/17 is not cheap...I then found out that Yokohama has a road hazard warranty...great! After some calling around I head down to the Yokohama guy to get a new tire covered under the warranty.
These tire warranties are a total crock. They prorate the tire wear from an artificial price for the tire that no one would ever pay! It turns out that I saved about $30 using the warranty program on a tire that was 9 months old and still had %63 (yes its that precise) good tread...if the tire is 50% then you might as well buy a new one and forget the warranty, the fees will make it more expensive than buying a new tire!
**Sorry, I had to vent**
At least I have four non-patched tires on the car!
Cheers,
Mike
Cheers,
Mike
