Cleaning matte black wheel
I got HRE p40 in texture black. I am wondering what is the best way to take care of them. Should I use wheel wax on them? Is it ok to use quick detail when drying the wheel? Lastly, I am getting water spot on the inside of the wheel after washing, what is the best way to get rid and prevent them.
Thank you
Thank you
Do not put any wax or cleaners on the matte black surface as it will stain or spot it. Soap and water on a cool wheel and not in direct sunlight. You could also use Simple Green and water.
-Enjoy the wheels!
-Enjoy the wheels!
Also, try the Car care forum, they may have more insight there...
https://rennlist.com/forums/concours-and-car-care-86/
thx for the help you guys
here is the wheel...its a texture black HRE P40...
most problems i i have right now is the left over water after washing the car...i tried blowing them out (with a blower), but there appear to be some left which cause water spot
I don't have flat black wheels but have always had good results with eagle 1 'all wheel and tire' cleaner. It sucks any gloss stuff and dirt out of the rubber and removes brake dust easy. The 'all wheel' variety leaves out rubber cleaner and seems pretty weak and is like a light soap mixture. The 'all wheel & tire' cleans even the wheel well plastic pretty good so great if you want to clean there too. There is an etched wheel they make but I'm not sure if you'ld want to try that. It works great on plain etched wheels though. Most the work is done by spraying any of the above on except the 'all wheel' that takes some scrubbing with rag or brush. All of them rinse off easy.
Super Moderator
Needs More Cowbell
Needs More Cowbell
P21S Total Auto Wash, orange in color (not the P21S wheel cleaner)
CR Spotless DI water filter.
Rejex application (optional but preferred)
EAGLE1 is great, when used with a pressure washer it equals no scrubbing!
I use the Mr. Clean Autodry car wash system which has a filter that actually removes minerals and deposits from the water and sprays the equivalent of distilled water on your car (I only use the filter part and not the wash soap). This filtered water can be easily removed to a near dry state with no remaining water spots. This works well on mat black trim and wheels. Another method which the way too **** previous owner of my car used to use is to do a final rinse of the black parts of the car (after washing) with a garden pump type insecticide sprayer and distilled water. Both methods will acheive similar results - no residual water spots.
Mick
Mick
