Mark this thread as Unsold
1986 944 Turbo, Black/black, very nice condition
Year: 1986
Make: Porsche
Model: 0
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 103236
Options (Please check ALL which apply): Air Conditioning, Alarm System, Foglamps, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: Black
VIN: WP0AA095XGN156480
Price (no $ sign please): $12900
Private or Dealer Listing: Private Listing
Location (Region): Texas
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Gallery of pics:
https://flic.kr/s/aHskPJ3g7A
18" Fikses FM10
Conti ExtremeContact DW - 245/40-18 & 285/35-18
Koni Adjustable front
Bilstein rears
H&R springs
15mm H&R spacers - front
Cross-drilled rotors
M030 front sway bar
Stage 2 chip
Cat-delete pipe from turbo downpipe to catback
Bullet muffler - straight-through design
A/C converted to R134a and fully functional
Pioneer CD/mp3 stereo
New/rebuilt:
Steering rack
Rack boots
PS reservoir
PS pump
Motor mounts
Injectors rebuilt by Witch Hunter
Tie-rods
Magnecor wires
Distributor Cap/Rotor, Bosch plugs
K&N filter
Cam belt
Balance shaft belt
Balance shaft seal collar (2)
Front engine seal kit
Water pump
Thermostat
Radiator Cap
Radiator Fan switch
Small turbo thermostat
Seals: Balance shaft seals, Crankshaft, Front engine seal kit,
Bushings: sway bar, drop link, control arm, steering rack
Sensors: Bosch knock sensor, DME Water temp sensor,
Fuel filter
Mounts: Idle valve mount
Thermo Valve 2.5
Rear Bilstein shocks
From Lindsey Racing:
Boost Enhancer
Bypass valve
Wheel studs
Silicone radiator hose kit
Silicone Hard pipe hose kit
AOS & Cycling valve hose kit
Silicone Idle Stabilizer/Venturi delete hoses
Cycling valve
Hard pipe hose kit
Idle stabilizer
Heater control valve
Oil cooler gasket set, Camshaft housing gasket
Maintenance in receipts:
Bosch 115W alternator – 10/13
Bosch fuel pump – 10/13
Rear Axles – 1/12 (Mayo Perf.)
Clutch salve – 12/12 (Stuttgart in Addison)
Clutch master cylinder – 12/12
Front brake hoses – 9/12 (Stuttgart)
Fuel lines – 6/12
FPR 3.0 – 6/12
Coolant reservoir – 6/12
ArnnWorx Timing belt kit
Arnnworx Throttle body reseal kit
Also available:
Catalytic converter pipe
Original phone dials
Stock airbox
Issues: Sunroof inop (likely gears), minor oil leak at oil pan gasket, left side gauge lights out
This is all I can think of at the moment. If I think of more details about the car, I will add them later.
Please email/pm with any questions about the car.
Asking $12.9k with the Fikses.
Interested in 951
Hi can i have your mail? Can you help me shiping it to laredo TX.... Thanks mgarciagtz@hotmail.com
I have a car I'd like to put a deposit down on this week. Very much interested in making a deal on this car or my Carrera asap. If anyone is interested in making a deal, let me know.
