Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
1970 911T -- Spec 911 racecar -- Blut Orange
Old 06-27-2016 | 08:57 PM
quickxotica's Avatar
quickxotica
Default 1970 911T -- Spec 911 racecar -- Blut Orange
Year: 1970
Make: Porsche
Model: 911
Cont. Porsche Models: 911
Mileage (numbers only please): 0
Color: Blood Orange
VIN: 9110120016
Price (no $ sign please): $46000
Private or Dealer Listing: Private Listing
Location (Region): NorCal
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Carbs
Stereo System: None
BUILD:
Chassis/Body:
• 1970 Porsche 911 T
• California car, street-driven until 2005,
• Original color Blood Orange (“Blut Orange”). Repaint is race-quality in same color.
• Vin# 9110120016
• Welded-in sunroof plug
• Steel 964 rear quarters
• FG 3.8 RSR short rear tail
• Wheels: Color-matched set of 16” Fuchs (7 & 8)
• Reinforced ARB mounts
• Wevo engine and gearbox mounts
• Front oil cooler
• Second oil cooler in fender
• Lightweight 911R taillight assemblies
• FG front bumper with brake cooling and oil cooler openings
• Custom splitter (shows some wear)
• Fabcar windshield holdowns
• Full roll cage by TC Designs
• Plexi front and rear screens (still serviceable but could use replacement)
• Original glass rear quarter windows
• Weight: Minimum legal weight with driver is 2350 lbs. This car requires some fuel and ~50lbs of ballast to meet that minimum with a 175lbs driver.
• Traqmate Complete data-acquisition & transponder included (hardwired).
Engine:
• 1978 3.0L (Records show engine# 6383739)
• Fully rebuilt in 2014 by Brian Kirkis (owner of The Stable). Roughly 10-12 hours on motor since. This rebuild included brand-new Mahle high compression pistons & cylinders, new bearings, etc.
• Large valve heads
• Race valve springs & retainers
• 46mm PMO carbs w/ tall manifolds
• Mahle high compression P&Cs
• Electromotive crankfire ignition
• 215mm small fan
• Pressure fed tensions w/ retainers
• Dual fuel filters
• Holley fuel pump
Gearbox:
• Magnesium case 915
• GT ltd. slip differential
• Rebuilt by Wevo/Brian Kirkis approx. 20 hours ago. (Note: when cold the 2-3 shift needs to be done slow, but once warm everything works great).
• Wevo gate shift
• Wevo shifter and PSJ
• Custom Rothsport CV joints and axles (super trick)
• Wevo mounts
Suspension:
• Smart Racing ARBs front and rear (adjustable)
• Wevo spring plate system
• Elephant racing ply-bronze bushings (F)
• Smart Racing mono-***** (R)
• Re-valved and shortened Bilstein front struts (new 2016)
• JRZ adjustable rear shocks
• Elephant Racing bump steer kit
• Smart Racing Torsion bars, 33mm Rear and 22mm Front
• All new wheel bearings in 2014.
Brakes:
• 944 Turbo calipers (front)
• Carrera calipers (rear)
• Carrera discs all-round
• 23mm master cylinder
• Motul fluid
Electrical:
• Fully re-wired, electrical disconnect, main power switch, fuel pump switch, push-button start (no key). The wiring not pretty but dead-simple and it works.
• Optima yellow-top battery
• High output alternator
• Dash-mounted fuses, circuits for pit radio, enduro lighting, lightweight blower
• Low fuel light in dash
• Large fan belt warning light
Interior:
• Stripped, gutted, repainted grey, holes drilled in floor for attachment of ballast weight, etc.
• Traqmate Complete with display unit mounted on center dash (hardwired to power)
• Rennspeed aluminum gas and dead pedals (stock brake & clutch pedals)
• Momo steering wheel with quick release and hub extension
• 2014 Cobra Suzuka Pro Kevlar driver’s seat (no passenger seat)
• Schroth harnesses (nearly dated-out)
• 2014 center & window nets
• Spa fire system with 2 nozzles (driver’s crotch and engine)
• Fuelsafe cell (large)
• Transponder
The bad: this car has seen some car-to-car contact. Never hit a wall, barrier or anything like that, but the bodywork shows evidence of repair & repainting (esp. the hood and the driver’s side rain gutter). The repaint is in the original color but is race-quality, not street-quality. It has non-original rear quarter panels (steel 964 ones). Most of the interior, original wiring & trim have been stripped. None of that stuff is included in the sale. It’s therefore not an easy candidate for conversion back into a street-car. The interior is not fancy.
I have owned it since early 2013. The previous owner is a friend. He bought it as a clean street car in ~2000, then converted it to a race car in 2005 and added the Jerry Woods-built 3.0L engine, which has since been rebuilt & improved (in 2014).
I have a binder full of records going back to the original owner. The car is NOT street-legal or registered, but I DO have the pink slip. Ownership will be transferred via bill-of-sale.
Please PM or email me (by clicking my username). Car is currently located in Berkeley and may be seen by appointment. I am also selling my Featherlite aluminum open trailer (see below).
This is probably your cheapest entry-point to a longhood 911 race car in an active class (Spec911 runs with both PCA and PRC/NASA).
Set that aside for a moment. Here's the real reason you need this car: It’s a weapons-grade adrenaline delivery device that happens to be a cute & collectible classic that your S.O. will adore. The 3.0L engine, suspension and associated running gear are all ready-to-race. The Spec911 class combines a strong power/weight ratio with relatively modest spec tires. This places a high emphasis on driver skill. See also: juevos gigantes.
Here’s how she goes:
These particular laps qualified me 8th out of 30 cars in Fall 2014. Pole-sitters were ~1 second faster. It has been serviced & stored since then, but not raced. It starts, runs and drives as it should. It has low hours on a professionally rebuilt motor (scroll down for the car’s build-sheet).
Thanks for reading.
John
Trailer:
• Featherlite 17.5' trailer - Model 3110 (all aluminum), built Aug 2012 as a ’13 model-year, roughly 6,000 miles on it. Can't even feel it behind the truck when it's empty. 7000lb GVWR rating, full deck, double axles, elec. brakes, hidden ramps, large nose guard.
• $4k, package deal preferred
Old 06-28-2016 | 08:41 PM
GT3DE's Avatar
GT3DE
A lot more pictures would surely help.
Old 07-01-2016 | 06:23 PM
quickxotica
Default Adding pics...
Adding pics... I took these last night.
Let me know if interested...
Old 07-07-2016 | 02:38 AM
quickxotica
1st bump.
Old 07-07-2016 | 05:41 PM
Shandingo's Avatar
Shandingo
Really cool car. Love it. Wish I was in the market for a car like this.
Old 07-11-2016 | 07:42 PM
quickxotica
Thanks Shandingo! I'm sorry to be letting it go, but I have no plans to return to racing, so go it must!
Old 07-12-2016 | 12:05 AM
P.J.S.'s Avatar
P.J.S.
Love it
Old 07-14-2016 | 04:43 PM
jumpman75's Avatar
jumpman75
3rd Gear
Interested in the trailer. Can't PM yet so you can email me @ jumpman1975 at gmail or you can PM me. thanks.
Old 07-15-2016 | 12:04 PM
EVOMMM's Avatar
EVOMMM
Default Wow
A1 build wish I did have the funds it would be in my garage today GLWS!
Mike
Old 07-18-2016 | 05:24 PM
quickxotica
For those interested in the trailer (I have PMs from several of you), please be patient. I need to wait until the car sells. This is not just in case the buyer wants both, but also so I have an easy way to move/deliver the car during the selling process. If the car sells without the trailer, I will contact the peeps interested in the trailer on a first-come-first-served basis. Thanks.
Old 07-21-2016 | 10:13 AM
eSon's Avatar
eSon
Fairly certain I've seen this car at NASA weekends. Great car at a great price. GLWS
Old 07-25-2016 | 01:56 AM
quickxotica
Thanks for the kind words. I've had a couple PMs, but the car is still available.
Old 08-01-2016 | 12:45 PM
quickxotica
Bumpity-bump-bump.
Old 09-01-2016 | 04:36 PM
Ina Peterson's Avatar
Ina Peterson
Any spares come with it
Old 09-10-2016 | 02:09 PM
quickxotica
Sale Pending.
Quick Reply: 1970 911T -- Spec 911 racecar -- Blut Orange
