Mark this thread as Unsold
1987 BMW 635CSi, formally Jonny A's car, Excellent condition
SPAM addict
Year: 1987
Make: BMW
Model: 6-Series
Mileage (numbers only please): 120000
Options (Please check ALL which apply): Air Conditioning, Cruise Control, Foglamps, Intermittent Wipers, Leather Seats, Power Door Locks, Power Windows, Sunroof
Color: Luxorbeige Metallic
VIN: WBAEC8403H0614524
Price (no $ sign please): $13995
Private or Dealer Listing: Private Listing
Location (Region): NorthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: AM-FM Cassette
Tim Thomas
207-266-4955 cell
treeinc@gmail.com
**Time to move this before winter**
For Sale:
1987 635 csi in stunning condition. Owned 12+ years, 10 year BMW CCA member.
Luxorbeige metallic restored orginal paint. Black Nappa full leather interior in near perfect condition. 120K. Getrag 265 5 speed. UUC short shifter, 3:91 LSD, front/rear A/C 134a, M6 3 spoke black leather steering wheel, E31 front calipers and rotors, E34 M5 rear calipers and rotors, Porterfield R4S pads, BBS RK 18" wheels with polished lips, Yokohama tires, H1/H4 headlights, Euro M635 rear spoiler, polished bumpers, tinted windows, all new suspension, Metric Mechanic 300 cell exhaust system. 5" thick binder documentation, clean carfax, always garaged. All parts used are BMW oem purchased from Bellevue BMW except upgrades.
Listed below is a full detail of what I have done/replaced/improved since I have owned my car.
Exterior:
Paint restoration of orginal paint, H1/H4 headlights, Hella foglights and lenses, front L/R kidney grills, L/R front grills, under hood grills, carbon fibre hood and trunk roundels, Bosch 18" wipers, polished F/R bumpers, rubber trim pieces all restored to new, euro M635 rear trunk spoiler, tinted signal lenses, tinted windows 30%, drivers side door lock cylinder assembly/heater, door handle gaskets, OEM front windshield.
Interior:
M-Technic M6 3 spoke black leather steering wheel, dual F/R A/C 134a.
Engine:
Rotor and distributor, voltage regulator, EVO 8mm blue silicon spark plug wires, Bosch wrl9s spark plugs, E32 750i solid mount polished alternator, radiator and cap, all cooling system hoses, thermostat, removed, cleaned and painted gas tank with Wurth black underbody paint, in tank fuel pump o-ring and gasket, fuel filter, fuel relay and main relay, Metric Mechanic 300 cell cat exhaust system, exhaust manifold painted with Wurth black heat paint, all heat shields polished, oxygen sensor, K & N air filter, polished valve cover, oem dip stick w/ o-ring.
Transmission:
Getrag 265/6 5-speed conversion, input shaft, output shaft and selector shaft seals, 265 bell housing, 14.55 lb. lightened flywheel, flywheel bolts, pilot bearing, pressure plate, clutch disc, throughout bearing, pivot lever, spring clip, nylon nipple, clutch pedal assembly, clutch/brake pads, slave cylinder, M/C, high pressure line, blue hose line, backup light switch, E34 M5 flex disc, longer bolts and nuts, UUC short shifter, UUC dssr shift rod, E36 selector rod joint, shifter platform, mounting blocks, shift tower rubber, shifter insulation block, black leather shift boot and frame, 5 speed black leather sport ****, Portland Driveline with greaseable u-joints.
Suspension:
Front:
oem sport springs, Bilstein sport shocks,oem upper bearing mounts, oem wheel bearings/hubs, oem L/R and center tie rods, idler arm, Road Race Technology spherical bearing steel thrust and control arms, Dinan 25mm 4 position sway bar, BMP Desigh aluminum spherical bearing adjustable sway bar drop links, BMP Design shock tower brace.
Rear:
Oem sport springs, Bilstein sport shocks, oem spring pads, gaskets, and guide supports, Oem bearings/hubs, oem pittman arms, RTRS poly carrier bushings, RTRS poly camber/toe adjustable trailing arm bushings, Dinan 19mm 3 way sway bar, oem sway bar drop links, 3:91 LSD, fully rebuilt with new bearings, clutch discs setup with a sport setting, drive axles rebuilt, new cv joints.
Brakes:
Front:
E31 850 csi calipers painted with Wurth black heat paint, BavAuto caliper brass guide bushings, E31 Ate 325mm x 30mm slotted vented rotors, Porterfield R4S brake pads, Goodridge SS brake lines, E32 M/C, oem accumulator, horizontal and vertical switches.
Rear:
E34 M5 Ate calipers painted with black Wurth heat paint, E34 305mm x 20mm vented rotors, Porterfield R4S brake pads, Goodridge SS brake lines, BavAuto caliper brass guide bushings. Ate blue racing fluid.
Tires and Wheels:
5 BBS Rk 18" x 8 1/2" bright silver with polished lips, carbon fibre wheel caps, 3 Yokohama AVS ES100 235/40ZR 18" tires, 2 Yokohama AVS ES100 265/35/ZR 18" tires.
SOLD, Going to the Midwest. Thanks
SPAM addict
