Wireless Rear view trailer camera...
Just hooked up a GoVue wireless rear view camera to the trailer. Pretty darn cool for $140! I did a hard wire to my battery tender quick disconnect opposed to wiring into the reverse lights. It had two options really, hard wire or into the reverse lights but if you hard wire it is always on and you can also use it as a live video feed from the rear of the trailer for passing, changing lanes etc... Not to mention I won't be getting out of the Macan checking how close I am in the back only to realize I am 11 feet away still, roll back 3 feet get out and check again and repeat 3 times Using the battery tender quick disconnect on my trailer battery means I can unplug it easily so the wifi transmitter isn't pulling a draw when not in use.
Just a Camera and wireless transmitter with an app on your phone.
Pretty cool.
Pretty cool.
Pretty cool.
Pretty cool.
It is pre-paired, works in real time as a rear view mirror not just back up camera and much better quality. I am very happy with the setup now, used it all the way to VIR and back without ever having a hiccup.
I am planning to try using two iPhones. I happen to have two because my work phone is also an iPhone. The plan is to mount one phone on the trailer and the other on the dash or windshield and then just do a FaceTime call between the two phones when backing up. I only need it when backing the trailer into my driveway, which requires a 90 degree backup approach and I have tall retaining walls on both sides of the driveway, so I can't see that well until the trailer is almost all the way into the driveway. Driveway is also only about 1.5x car widths wide, so not much room for error.
Most GoPro cameras have a phone app so that you can stream a live feed to the phone. Since many of us track enthusiasts have GoPros (and the accessory suction mounts), this might be a simple way to temporarily use the camera for backing up and/or loading the car on/off the trailer.
I've tried a few setups now - I'm on rev 4. The one I think will be the last revision is more of a DIY approach, but it's bullet proof. If you are geeky, PM me for details. Basically it's a 4-channel analog to streaming digital encoder plugged into an outdoor 5GHz AC access point, with a standard ipad/iphone IP camera viewing app. I'm using the cheapo amazon chinese cameras on the sides and rear. Works really well in place of longer mirrors. I'm contemplating putting a wide angle camera on top for road use, or one inside, for the 4th camera.
I found a new Hyndsight setup on ebay for $240 and figured WTH. Happy with it so far, video is OK, not great. Super simple to setup. Charge camera, push button, attach screen to windshield. I'd recommend the 'wide' setup as I bought the standard and while still useful... I would definitely trade for a wider lens
Battery life is about 6-8hrs on the camera, so I didn't even bother hardwiring it.
Why would you prefer the wide camera over the standard one? Have you found the standard one leaves you with blind spots in specific circumstances or generally? Did you know you can buy just the wide view camera without the monitor? Amazon price for the full kit is much higher than the price you paid on ebay it would seem.
Basically, I can see either the view behind trailer (area not covered by mirrors) OR I can point the camera down and see how close I am to a fence. I figure with the Wide version you could do either (or at least a better chance of it)
I want to say normal FOV is 60 or 45 degrees and Wide is 90?
Swap in a wide, you'll love it. I have a wide angle camera on our RV and I can see my rear bumper and far enough behind me that i can see the ground behind my open trailer. Really gives you a sense of what's back there and very useful backing up.
are there any versions that are battery powered ?
looking for something that i can just stick on the back of whatever i am driving and have it sinc to my phone
than remove when finished
thx
thx
