Open aluminum trailer vibrations
Old 09-23-2021, 11:25 AM
  #46
m3bs
m3bs's Avatar
I’m pretty much at the same point with mine. The only thing I can add is that it improved after rotating tires on my Expedition, so replacing them may be my next move.
Old 09-23-2021, 03:02 PM
  #47
Quadcammer
Quadcammer's Avatar
Received 1,392 Likes on 808 Posts
sorry man, really frustrating stuff. One thing I'm considering is taking the tilt deck off with a 2 post lift and trying to tow it without a deck to see how that impacts it. it seems the tilt models may be worse for this.
Old 09-24-2021, 11:13 AM
  #48
badabing
badabing's Avatar
Have you checked the runout of the tires (roadforce)?
Old 09-24-2021, 04:27 PM
  #49
Quadcammer
Quadcammer's Avatar
I haven't, but I have run tires from my friends trailer, and the issue did not change at all, so I'm not seeing it as a tire issue.
Kein_Ersatz (09-28-2021)
Old 09-27-2021, 04:28 PM
  #50
vwmurph
vwmurph's Avatar
I'm getting pretty frustrated with my situation as well. I have a similar vibration around 68-72 mph that comes and goes. It's happened with the last three trucks I've owned (GMC 2500's 05,13 &18) and three 18' Aluminum trailers, 2 Mission and 1 ATC. All three trailers have been 18' aluminum deck, open trailers with 7000k lb GVWR. I've tried all combinations of balancing truck and trailer wheels to no avail. The only common thread is it's always been the same 911 on the trailer. I borrowed a friends Trailer enclosed trailer and drove 625 miles to WGI last month with no vibrations. I'm starting to think its time to buy an enclosed trailer
Old 09-28-2021, 08:45 AM
  #51
57nate
57nate's Avatar
Have you tried having someone driving beside the trailer while you drive down the road to figure out what is vibrating? You should be able to figure out if it is a tire, the shield or something else. I would also check axle alignment with a tape measure.
Old 09-30-2021, 09:29 AM
  #52
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
I'd go with aero. I have a 2011 GMC Yukon XL Denali and an open Trailex with shield and 4 extra spare tire holders for track wheels. If I run without tires on the spare holders, it vibrates just like you describe. If I put the tires on, smooth as can be. I have not experiences this with the same trailer on a 2005 Yukon, 2011 GMC pickup, 2005 Nissan Titan, and 2016 Pathfinder. It's very odd, but certainly aero. I would try adding something to change the airflow near the fenders.
Old 09-30-2021, 10:25 AM
  #53
Quadcammer
Quadcammer's Avatar
so I already have removed the shield. You are suggesting that the fender covers may be the issue?
thanks
Old 09-30-2021, 04:07 PM
  #54
Matt Romanowski
Rennlist Hoonigan
thanks
Maybe. The shield is mostly in the wake of the tow vehicle, so I think it's more along the side of the trailer. I would do something to change how the air goes around the tow vehicle and back to the trailer.
Quick Reply: Open aluminum trailer vibrations
