Concerning issues with my Taycan
The following 3 users liked this post by DerekS:
You’ll want to just buy a 3rd party one
I'd live with the included (free) EVSE before worry'ing too much.
I do recommend you follow Porsche's install recommendations for a high quality commerical/industrial grade NEMA 14-50/6-50 power socket - this is good advise for _ALL_ EVSE's and mirror's many other EV vendor's recommendations - for details you can review post #93 in this thread for Porsche's "official"recommendations…https://rennlist.com/forums/taycan/1...l#post18495910
post #15 also has my analysis and reference to other threads with additional information.
while I'm not a fan of the included PMC+ or (optional $1120 PMCC) I'd recommend "living" with it before spending additional funds on a replacement - if it gives you any problems alternatives are easy to obtain, reliable, compatible, and the PMC+ can simply be stored/ignored should that be a requirement.
alternatives start as low as $200 and go up from there…and there are numerous non-Porsche high quality high confidence alternatives.
The following 2 users liked this post by daveo4porsche:
DerekS (01-11-2023),
wutographydc (01-29-2023)
the 19.2 kW option shoudl be avoided in north america unless you have a specific use case in mind and plan to install a 100/80 amp EVSE in your home(s) - you are unlikely to run into 19.2 kW EV chargers "in the wild" in North america - so it's primary use case is for reducing charging time at your home, work, vacation home, but requires a substantial investment in a dedicated 100 amp 240V circuit and a corresponding 100/80 AMP EVSE - consult with a local electrician on cost and feasibility of adding a dedicated 100 amp 240V circuit to your residence prior to optioning this feature - the cost of this features is:
- Porsche options cost ($1680)
- 100 amp EVSE ($1700 or more)
- additiona of a dedicated 100 amp circuit to your home ($2000 or more)
also please consider any effort/cost/expenses you put into an EV charger for your home is also 99% likely to be fully compatible with your Taycan and any future EV you will eventually bring home - so this is is a long term investment for all your EV's not just your Taycan.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/540x2000/2cc578a6_b89f_4a67_af11_4be8414e2dfe_6649edaab6884a028a034bf691e8ca79d9cd3e3d.jpeg)
The following 3 users liked this post by daveo4porsche:
while I will apologize for the length of these threads - I will not apologize for the quality or thoroughness of the content - the following threads remain in my opinion the best resources for new EV owners looking to come up to speed on "what the heck" should I do for my home EV charging…and lot of ground is covered in the following threads and the information you need/want is in these threads - there is virtually no topic regarding home EV charging that is not already covered somewhere in these threads…
https://rennlist.com/forums/taycan/1...-charging.html
https://www.taycanforum.com/forum/th...cc-pwcc.13886/
https://www.taycanforum.com/forum/th...-….2343/
https://www.taycanforum.com/forum/th...-update.12791/
https://www.taycanforum.com/forum/th...….11745/
https://www.taycanforum.com/forum/th...-review.13163/
this is what can happen if you use a "cheap" NEMA socket w/Porsche PMC+/PMCC due to Porsche failing EE 101 and shipping their PMC+/PMCC with a substandard power supply cord which can get quite hot - not hot enough for the porsche part to fail - but hot enough for lesser parts Porsche might be plugged into to become thermally stressed and potentially fail…
https://www.taycanforum.com/forum/th...5/#post-214735
The following 2 users liked this post by mjw930:
daveo4porsche (01-05-2023),
DerekS (01-11-2023)
