Taycan pics
Old 12-22-2019, 08:11 AM
  #61
Cpoarchy
Cpoarchy's Avatar
Oh.. I see, didn't think you would need to do that, doesn't the battery only start the car only?
Old 12-22-2019, 11:21 AM
  #62
PistolPete
PistolPete's Avatar
Originally Posted by Cpoarchy
Great pics! What's the cable going inside the frunk?
Standard CTEK 12V charger. I'm not sure how the power works on this thing but as a floor demo, they had the headlights (or at least the driver lights) and the dash electronics all powered up.
Old 12-22-2019, 12:17 PM
  #63
Cpoarchy
Cpoarchy's Avatar
I see, thanks, was curious, still crazy we still need a 12 volt battery, but I get it
Old 12-22-2019, 09:37 PM
  #64
Cpoarchy
Cpoarchy's Avatar
Default Nice volcano
The following 4 users liked this post by Cpoarchy:
mikkm (12-25-2019), svp6 (12-22-2019), TopspeedPT (12-27-2019), Wilsontour (12-29-2019)
Old 12-22-2019, 09:48 PM
  #65
Bob Roberts
Bob Roberts's Avatar
How did you like the Neodyme trim? debating that and the dark silver.
Der-Schwabe (12-23-2019)
Old 12-22-2019, 09:57 PM
  #66
MotoJB
MotoJB's Avatar
Did you all see the Smoking Tire review where in 17 miles in sports plus mode, Matt used up 40% of the battery?
I get it, don't drive around in sports plus with A/C all the time and you'll achieve a better range...but still...that's pretty disappointing results IMO.
Old 12-22-2019, 11:51 PM
  #67
Cpoarchy
Cpoarchy's Avatar
View this post on Instagram
Old 12-23-2019, 12:43 AM
  #68
Bob Roberts
From the video (at around 4:30), after using up 64% of the battery, they had 74 miles left, implying that they were running at a 206 range so not sure how that 40% in 17 miles works out
Old 12-23-2019, 12:53 PM
  #69
shake1
shake1's Avatar
Here are a few poor cell phone shots I took at my local dealer. Was not expecting there to be one in person. Looked very low to the ground, very similar proportions to a 4 door 911. Even these rims look good in person. Huge fan after seeing it in person, will go back another day to test out the back seats for comfort.
The following 2 users liked this post by shake1:
Cpoarchy (12-23-2019), TopspeedPT (12-27-2019)
Old 12-23-2019, 02:24 PM
  #70
Needsdecaf
Needsdecaf's Avatar
Received 2,603 Likes on 1,618 Posts
The majority of the ancillary systems are still powered by 12v, since they are sourced through typical Tier 1 suppliers. Windows, lights, displays, etc. All that requires 12v. which means you've got to have a battery.
Old 12-23-2019, 02:34 PM
  #71
AlexCeres
AlexCeres's Avatar
Received 1,681 Likes on 1,030 Posts
that’s .... sad.
Old 12-23-2019, 02:44 PM
  #72
GreggT
GreggT's Avatar
So.....we are saying, a conventional 12V batt of some kind....and, how does the car keep it charged? Also an alternator?
Old 12-23-2019, 04:56 PM
  #73
whiz944
whiz944's Avatar
There is a DC-DC converter in EVs that provides power to the 12V system from the HV battery pack. Like an alternator, it also keeps the 12V battery charged. Typically the 12V battery is also trickle charged when the car is plugged in.
A critical function of the 12V system is to 'boot' the car during power-up. Not only the computers and whatnot, but also to turn on the high voltage contactor inside the battery pack to allow HV power outside the pack.
It really shows a lack of clue to run a separate 12V battery tender. They should just plug in the normal charge cord.
Old 12-23-2019, 04:58 PM
  #74
4pipes
4pipes's Avatar
Most are motorcycle type batteries that are charged when the main battery is charging. The cars in general already have a dc to dc capability, but for safety and convenience, need an ancillary 12v battery. These batteries have a typical life of 4-5 years and when they die, the car is immobilized.
Old 12-23-2019, 05:09 PM
  #75
whiz944
whiz944's Avatar
True - the 12V batteries are typically small lead-acid AGM. So yes - they do get weak and go bad after some years. You'll hear stories of folks who have parked their car at the airport for a few weeks, not plugged in, that will find their cars unable to start up - just like any ICE car. A quick jump turns on the HV pack - which then charges the 12V battery. Some folks keep a small, separate, 12V Li-ion jumper battery stowed in the car "just in case".
Quick Reply: Taycan pics
