Spyder/Cayman R Discussions about the 987 Spyder/Cayman R (2011-2012)
Sport bucket seat adjust
Old Nov 25, 2021 | 02:31 AM
  #46
jfl503's Avatar
jfl503
For you tall guys (with seat lowering rails), is this rennline kit a solution to fitting the belt receptacle? Are OEM sleeve spacers really 40$ each...??
https://www.rennline.com/Harness-Mou...ductinfo/SA03/
Old May 15, 2024 | 12:42 PM
  #47
vantage's Avatar
vantage
Originally Posted by John McM
All installed. My goal was to increase the seat rake as that’s most comfortable for me. At the same time, given my 6’ 4” height, I needed to maintain the gap between my legs and the steering wheel.
To do that, I kept the front at OE height and dropped the rear mount one hole. This increased rake by 4 degrees. I have not measured headroom as was not hitting it before but it should have increased by 16.5mm or 0.65”.
Luckily I had some seat belt fittings in my stash otherwise I couldn’t have installed the rails as supplied. The challenges are as follows:
1. There are no instructions with the rails.
2. The after market rails have threads inside the rails whereas the OE rails have raised threaded collets. This means you need longer bolts. The seat belt side can be fastened with the OE bolt but I was uncomfortable with the number of threads engaged.
3. The seat belt receptacle is concave. You need to use a collet etc to make it fit.
4. While the seat bolts in with the rails, I believe the method used for the front is twisting the rail underneath. It didn’t fit as easily as OE. I can’t be bothered playing with it but i would look at longer front bolts and collets.
Hi John. You and others have been really helpful in this thread.
Would you still recommend these lowering rails? Any issues with rubbing or marring the carbon fiber?
For #3, I think I understand what you are saying based on the shape of the bottom of the seat belt buckle loop that attaches to the seat. For #4, are you saying that you'd also recommend some sort of spacer or collet between the new rail and the side of the seat for the front bolt? As I understand your earlier post, Cantrell provides a spacer for the rear bolt, but not the front.
Old Sep 3, 2024 | 07:09 PM
  #48
bertsboat's Avatar
bertsboat
Try these for better lumbar support and they are fairly priced.
https://www.radiatorgrillstore.com/p...lumbar-support
Old Sep 10, 2024 | 01:14 PM
  #49
Skid's Avatar
Skid
@John McM With the tilt, were you still able to have the seat slider position all the way back without the top of the seat hitting the rear bulkhead? I’m 6’3”, long legs and keep the seat full back. Would like to go with this tilt kit but wonder if it would force a more forward slider position. Thanks
Old Sep 10, 2024 | 06:57 PM
  #50
John McM's Avatar
John McM
I just checked. If I move the back forward and slide the seat fully back, I am not able to recline the seat back and have it click.
Just our secret. I love the sofa vs LWB debate as I have the latter. However my second Spyder has the sports seats and they seem to sit a lot lower and give me more legroom.
